Author Topic: No spark.  (Read 2963 times)
Offline YellowThumper
  • I left the snow for this?
Re: No spark.
« Reply #15 on: March 16, 2016 - 03:26:28 PM »
new cap and rotor?  recheck the reluctor gap
This and have you checked the distributor shaft play. Worn out bushing will allow it to bounce around and get inconsistencies in gap/spark.
Offline 734406pk
  • Andy
Re: No spark.
« Reply #16 on: March 16, 2016 - 07:20:22 PM »
I've swapped ECU's and got a constant spark, but still no spark from plug wires
Do you have a consistent 3/8" or better spark from the coil wire ?
Offline Cuda_451
Re: No spark.
« Reply #17 on: March 16, 2016 - 10:17:31 PM »
I have a whole new distributor, rotor, cap, and gear from Mancini, the spark from coil is a bright blue and it plenty long enough, also have newer spark plug wires I have not checked the air gap yet
1970 Plymouth Barracuda
1995 Dodge RAM 1500 SLT
2006 Ford Mustang V6 Supercharged
Offline 734406pk
  • Andy
Re: No spark.
« Reply #18 on: March 17, 2016 - 09:23:22 AM »
Check the condition of the rotor and inside of the distributor cap, especially beneath where the coil wire attaches to the cap and contacts the rotor. There is a rotor inside this distributor right? :thinkerg:
Offline Cuda_451
Re: No spark.
« Reply #19 on: March 17, 2016 - 09:53:48 AM »
Yes there is a rotor, it came with the distributor.
Offline 734406pk
  • Andy
Re: No spark.
« Reply #20 on: March 17, 2016 - 07:50:18 PM »
Had to ask...sorry! Do you have a "known good" sparkplug wire that you can use to test spark output from the distributor? Or i can tell you how to make a HV test probe so you don't get zapped, maybe....You should have the same spark intensity that you saw at the coil wire coming out of the distributor, only at 1/8 the interval since the spark output is being "distributed" to the spark plugs.
Offline Cuda_451
Re: No spark.
« Reply #21 on: March 17, 2016 - 10:36:15 PM »
I tried placing the wire to the header and had no spark at all. How do you make that test probe? Lol
Offline 734406pk
  • Andy
Re: No spark.
« Reply #22 on: March 18, 2016 - 10:28:02 AM »
To make the HV probe, you will need a #2 phillips screw driver with a 4-6" long blade, and a 2-3" piece of 12 to 14 gauge automotive primary wire. Strip each end of the wire and securely crimp a 3/8" id ring terminal to one end and an alligator clip (that will securely grip the phillips screw driver blade) to the other end. Find a bolt (like an intake manifold bolt etc) near the distributor and attach the ring terminal there. Attach the 'gator clip to the metal screw driver blade. That's the probe. Now pull out one of the plug wires from the distributor cap. Place the probe into the distributor cap where a wire was and have someone crank the engine. Hold the plastic handle only and slowly draw out the screwdriver and you should be able to get 1/4" to 3/8" spark length from each plug connection. As long as the wire stays connected to the engine/screw driver, you will not get zapped. This method will test your spark output potential to your plug wires. Good luck and be careful! :thumbsup:
Re: No spark.
« Reply #23 on: March 18, 2016 - 11:18:20 AM »
Also make sure screw driver handle is fully insulated. Not with a metal cap on back of handle. Ask me how I know this. Only happened once though. Lol
Offline Cuda_451
Re: No spark.
« Reply #24 on: March 18, 2016 - 08:08:15 PM »
Imma give it a shot tomorrow lol maybe I won't get a shocking surprise lol  if I don't get any spark, what could it be?
Offline 734406pk
  • Andy
Re: No spark.
« Reply #25 on: March 18, 2016 - 08:16:11 PM »
Well if you have a nice hot blue spark 3/8" or better out of the coil wire and you get no spark from the plug terminal of the distributor cap, there is a HV short within the distributor. Very unlikely, but possible. Post back results, good luck and work safe!
Offline Cuda_451
Re: No spark.
« Reply #26 on: March 18, 2016 - 08:28:27 PM »
Thanks! I'll need it lol
Offline Cuda_451
Re: No spark.
« Reply #27 on: March 18, 2016 - 08:33:11 PM »
This was the problem with the first distributor too and I bought one hoping to resolve the issue so I'm pretty sure the problem ain't in the distributor. Also has a new wiring harness too.
Offline 734406pk
  • Andy
Re: No spark.
« Reply #28 on: March 18, 2016 - 08:41:17 PM »
At this point, there is not very many things that it can be. Good luck with your test!
Offline Cuda_451
Re: No spark.
« Reply #29 on: March 18, 2016 - 09:32:22 PM »
Anything else to check?
