Author Topic: 14 inch steel rim for 70 cuda  (Read 1178 times)
Offline BadJoey
« on: March 12, 2016 - 01:49:27 PM »
I have 3 but need a 4th one . That is I need 1 steel rim that will fit the poverty cap 14 inch rim . I'm near rome NY.
Offline loco340cuda
Re: 14 inch steel rim for 70 cuda
« Reply #1 on: March 13, 2016 - 07:34:31 PM »
I don't anything about this seller but I figured I would pass this along incase it was helpful........
http://phoenix.craigslist.org/evl/pts/5437578934.html
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Offline A93
« Reply #2 on: March 14, 2016 - 08:41:48 AM »
Those rims come is three sizes! What size are your other three???  14x5.0, 14x5.5, and 14x6.0 are your options. Let us know, I may be able to help out depending on the size.
Offline BadJoey
« Reply #3 on: March 14, 2016 - 10:16:47 AM »
The other 3 rims are 5 inches wide from inside of lip to inside or 6 inches outside to outside . It has to hold a poverty hub cap which is 8 3/4 inches around . Any help would really be great . Thanks
Offline A93
« Reply #4 on: March 15, 2016 - 08:31:12 AM »
Are they the original rims that came with your car? If they are they will be 14x6.0  Any chance you can post a close up picture of one of the rims showing the valve stem area? There are numbers stamped to the right and left sides of the valve stem hole, and possibly a seven digit part number stamped above the valve stem hole. That would help a lot.
Offline BadJoey
« Reply #5 on: March 15, 2016 - 10:02:17 AM »
The guy I bought them from said they came off a 72 Challenger , which don't mean anything the 4th rim looked to be off a truck .Is there a reason I could not use a 6 inch with 3 5's ? If thats the size you have . What kind of car came with 5 inch rims . By the way no way can I do the pitcher thing . The trim ring is 8 3/4 inches across with out the humps that hold the cap on .
Offline BadJoey
« Reply #6 on: March 15, 2016 - 06:24:27 PM »
A friend showed me how to measure them . I need a 6 inch rim that will hold the poverty cap Thanks . I'm learning new stuff all the time .
Offline A93
« Reply #7 on: March 17, 2016 - 12:33:16 PM »
A 1970 cuda with a 340 would come with a 14x6.0 rim. Base model Barracuda's could come with 14x5.0, 14x5.5 and 14x6.0 steel rims.  If you are just looking for any 14x6.0 rim, you should be able to find one somewhere.  If you want correct 14x6.0 rims for your car, PM me and I can help you out.
Offline BadJoey
Re: 14 inch steel rim for 70 cuda found one
« Reply #8 on: March 19, 2016 - 02:32:53 PM »
Thanks for all the help I got one locally . :ylsuper:  A new friend had a friend delivering a Trans from a couple hundred miles away and he had one . :cheers:
By the way ICOC I tried the craigs list guy but got no answer thank you
« Last Edit: March 19, 2016 - 02:36:23 PM by BadJoey »
