Author Topic: 400 build  (Read 7690 times)
Re: 400 build
« Reply #30 on: March 20, 2016 - 08:42:00 PM »
Offline Cuda_451
Re: 400 build
« Reply #31 on: March 20, 2016 - 11:02:41 PM »
I'm running 15x10 wheel in back so would those still fit?
1970 Plymouth Barracuda
1995 Dodge RAM 1500 SLT
2006 Ford Mustang V6 Supercharged
Re: 400 build
« Reply #32 on: March 20, 2016 - 11:28:30 PM »
  275's would be a stretch ...305's would fit the rim better but you probably will have clearance issues if the wheel wells are stock.
http://www.nittotire.com/race-tires/nt555r-dot-compliant-competition-drag-radial-tire/
Have you considered stepping up to modern size rims? 17" or larger will give you a LOT of options.  Personally going 17"
Offline Cuda_451
Re: 400 build
« Reply #33 on: March 20, 2016 - 11:46:21 PM »
Im running air shocks for now and the rear end is narrowed so I'm away from the leaf springs and the top of wheel well. They are about even with my fender though. Any suggestions now? I'm looking for a tire that will catch when I gun it but also has long treadlife.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: 400 build
« Reply #34 on: March 21, 2016 - 10:17:17 AM »
Check out M/T Sportsman SR's, just ordered these for my '68 Charger  - http://www.mickeythompsontires.com/street.php?item=SportsmanSR
Hoosier has their Pro Street Radials and are a little bit more - http://hoosiertire.com/pdfs/prostr.pdf
