Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
What Gear Oil For My Dana 60 w/Strange Axles and Spool?
« previous
next »
Print
Pages: [
1
Author
Topic: What Gear Oil For My Dana 60 w/Strange Axles and Spool? (Read 2107 times)
Oldschool
Administrator
Permanent Resident
Member Since 9-05-06
on:
March 15, 2016 - 08:24:27 AM »
I discovered that the ring gear that is currently in the car has a broken tooth. I am going to be proactive and replace the ring and pinion using a new install kit. I am going with a direct replacement gearset. Richmond Gear Pro set -- 4.10 ratio. What weight and type of gear lube should I use. Synthetic or mineral oil based? Just wondering what the consensus is...... Thanks in advance...
Logged
Ken -- In Georgia
Moparal
Permanent Resident
Re: What Gear Oil For My Dana 60 w/Strange Axles and Spool?
Reply #1 on:
March 15, 2016 - 11:11:36 AM »
I use royal purple in my cars zero weight in my Dana in the Cuda , but it is a quarter-mile car only, Road Runner I went to royal purple 80 wait streetcar 354 gears
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
March 15, 2016 - 11:13:45 AM »
While synthetic has less friction I have heard of numerous problems using syn in diffs so I would use a premium 80w-90 gl4 like castrol
Logged
Oldschool
Administrator
Permanent Resident
Reply #3 on:
March 15, 2016 - 11:16:12 AM »
We use BG SAE 75w-140 full synthetic in most of the hot rods that come in here. Will that work ok, or should I go a different direction?
Logged
Ken -- In Georgia
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
March 15, 2016 - 11:32:19 AM »
I am sure it will work but maybe that is why you have a broken tooth ?
There is no need to go to 75-140 IMO 75-90 would be better
http://www.lastgreatroadtrip.com/wp-content/uploads/2010/11/gear-oil-comparison.pdf
Logged
Oldschool
Administrator
Permanent Resident
Reply #5 on:
March 15, 2016 - 11:40:42 AM »
It looks like 75w-90 it will be. Thanks guys - I knew I could count on y'all...
Logged
Ken -- In Georgia
brads70
C-C.com Expert
Reply #6 on:
March 15, 2016 - 12:45:17 PM »
My new Dana from Cass came with a couple jugs of 85w-140 from Lucas if that helps?
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
