Author Topic: Sharing: Tinted Bedliner Interior Coating  (Read 2327 times)
Offline GoodysGotaCuda
« on: March 16, 2016 - 10:28:33 PM »
I was able to wrap up the interior sheet metal today for my Barracuda. I wanted to have a color matched interior/trunk but I wanted the trunk to be something that could also be used. Ice chests, chairs, strollers, parts, whatever rolling around back there will end up eating up a nice trunk. An additional benefit I see of the bed liner is some noise reduction and thermal insulation as well.
I used a coating by U-POL called Raptor Liner, it's tinted with 10% base coat, which is Lemon Twist yellow. It should fully cure in 5-7 days and be tough as nails. So far I am very happy with the results!
https://www.facebook.com/GoodysGotaHemi/
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 1 Wild R/T
Re: Sharing: Tinted Bedliner Interior Coating
« Reply #1 on: March 16, 2016 - 10:50:15 PM »
Nice!!
Offline Rdchallenger12
« Reply #2 on: March 16, 2016 - 11:11:14 PM »
That looks fantastic! I wonder if it would stand up to being an undercoat.
« Reply #3 on: March 16, 2016 - 11:16:43 PM »
I wouldn't doubt it. Actually I plan on buying a black kit for the under carriage  and wheel wells.
1976 Dodge Warlock
Offline 67vertman
  • Member since 9-23-2005
« Reply #4 on: March 16, 2016 - 11:28:29 PM »
Goody, I like it....looks good and usable as well.  :cheers:
Offline shawge
  • Zoiks!!
« Reply #5 on: March 16, 2016 - 11:37:08 PM »
That looks great!
- Jerry
Offline GreenFish
« Reply #6 on: March 17, 2016 - 12:21:08 PM »
looks great, how much did you have to prep the surface for application?
Offline moprr
« Reply #7 on: March 17, 2016 - 04:28:55 PM »
Looks good how much did you use?
« Reply #8 on: March 17, 2016 - 06:48:28 PM »
Some new sheet metal there was  scuffed and shot with epoxy primer, then coated with single stage base coat yellow. Once cured I red scotch-brited the surface, wiped it down and shot.
1976 Dodge Warlock
« Reply #9 on: March 17, 2016 - 06:49:25 PM »
4L kit provided just over two full coats. Including the trunk.
1976 Dodge Warlock
Offline JpRngr
« Reply #10 on: March 19, 2016 - 01:17:09 AM »
I did my full interior including the underside of the roof and the trunk with the black Raptor Liner. Went on real easily and is very durable.
Corey
