440 HP Manifolds
Author Topic: 440 HP Manifolds  (Read 2134 times)
Offline Claudia
440 HP Manifolds
« on: March 18, 2016 - 03:54:29 PM »
Can anyone provide me with the casting numbers (or pictures) of the correct 440 HP manifolds for a '71 E-body.  I'm not looking for a certain cast date or time.  I'm just wanting to ensure that I purchase a set of 440 HP manifolds that will work in my '71 Cuda.
Offline AussieMark
Re: 440 HP Manifolds
« Reply #1 on: May 16, 2016 - 06:01:10 AM »
I am sure all the B and E body big block high performance manifolds are basically the same I have a pair left over from a 1968 440 Charger (1968 castings) that I will eventually use on a 1970 Barracuda. I also have one manifold that is a 1973 casting it looks a little different with some ribs on the side and some bolt holes (for a heat shield?) but it would be a direct replacement for the earlier manifold.
Offline 750-h2
« Reply #2 on: May 16, 2016 - 08:48:22 AM »
 Right 2899879 Left 2951865. While other year manifolds will fit on the engine the head pipe will not bolt on if you are planning on using 71 head pipes.
« Reply #3 on: May 16, 2016 - 08:47:26 PM »
If you use TTI exhaust they will ask for the manifold #s  so they will bolt up correctly
Offline 1 Wild R/T
« Reply #4 on: May 16, 2016 - 09:58:44 PM »
68 right side is definitely not the same as 70.... And C body left side is different....
« Reply #5 on: May 17, 2016 - 12:24:20 AM »
Offline Claudia
« Reply #6 on: July 19, 2016 - 10:21:27 AM »
Thank you all for the help . . . I just purchased a set of HP manifolds.
LH or Driver Side - 2951865 / RH or Passenger Side – 2899879
