Thanks guys for the replies...
I was hoping i could just find some fittings for what i have and be done with it. The link 1 Wild R/T posted is spot on for what i am looking for...
I don't know much about In line tubes other than that is where i bought my lines, etc at Carlise...
I already have $ 65 into the valve i have,,,and wonder if i should try the fittings for a few bucks and see if it is ok ??
Chryco....
Do i "need" a porportioning valve for a 4 wheel disc car ? ( i thought that was for rear drums and front disc's ? ) I am no brake expert by any means,,
I will say on my 65 Belvedere strip car,,,i have 4 wheel disc's and have the wilwood line adjustable block,,,, and that thing stops just fine at the end of the quarter mile...
Do you think the Wilwood would bolt up with my current stop brake lines ? ( or does it come with adapters ? )
Do you think the Wilwood set up is MUCH better than what i am thinking of using with the "stock" set up ?
Thank you !! very helpful info.......
Doug
