Author Topic: Cuda exhaust needed.  (Read 2834 times)
Offline copper01
« on: March 19, 2016 - 06:44:18 PM »
I have headers on my 70 cuda with mufflers and aar tips in front of the tires.  (I prefer the sound of my mopars out the back) but I am planning on leaving it in front of the tires. My qs is does anyone offer a kit from the header collector to the exhaust tip running performance mufflers like flowmasters?   I would like to have the in/out on the one front of the mufflers like the factory aar setup.  Thanks
Re: Cuda exhaust needed.
« Reply #1 on: March 19, 2016 - 11:55:49 PM »
TTI should be able to help you out with different options on pipe size etc but there are very limited choices with entry & exit on the same end
Offline copper01
« Reply #2 on: March 20, 2016 - 12:30:43 AM »
Ill ck with them..Thanks
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #3 on: March 20, 2016 - 10:30:07 AM »
One thing to consider with the in/out on the same side of the muffler is that set up is very restrictive and performance limiting.  I had the AAR set up on mine and took off those mufflers, installed an x-pipe and bullet straight through Magaflows and kept the side exhaust.  Sounds a whole lot better and I gained some TQ and HP, not a ton but ever little bit helps.
Offline copper01
« Reply #4 on: March 21, 2016 - 12:41:52 AM »
That looks nice.
Offline Cudakiller70
« Reply #5 on: May 07, 2016 - 02:17:39 PM »
That is a nice and clean install!  Are you using shorty tube headers or stock exhaust manifolds? Do you have any audio you could post?
The above is just my opinion
John Adams
Offline dfrazz
« Reply #6 on: June 05, 2016 - 11:47:27 AM »
https://vimeo.com/169435682
Seems to sound louder in person but here you go.
« Reply #7 on: June 05, 2016 - 10:54:17 PM »
Sounds good, but ya audio recordings aren't like hearing the real thing. Your install is simple and clean I like it. I may make my Cuda an AAR clone someday, may do something very similar. Thank you for taking the time to post it!  :2thumbs:
« Last Edit: June 05, 2016 - 10:56:37 PM by Cudakiller70 »
John Adams
