Author Topic: Transmission linkage  (Read 4873 times)
Offline 1 Wild R/T
Re: Transmission linkage
« Reply #15 on: March 20, 2016 - 06:54:31 PM »
The bell crank that mounts on the intake has three holes, two in the bell crank & one in the mounting bracket... slide a drill bit (I think 3/16") through those holes to lock the bell crank, now set the lower linkage length by adjusting the vertical rod so the throttle lever is all the way forward..... Next set the link from the upper bell crank to the carb so when the throttle is wide open the transmission kick down lever is fully rearward.....  This will get you very close, from there you can make small adjustments to tailor  the shift points..
Offline Cuda_451
« Reply #16 on: March 20, 2016 - 07:09:19 PM »
Okay, thanks!
1970 Plymouth Barracuda
1995 Dodge RAM 1500 SLT
2006 Ford Mustang V6 Supercharged
« Reply #17 on: March 20, 2016 - 08:36:48 PM »
make sure with the carb at wide open throttle the linkage is pushed all the way back also make sure the linkage in not preventing WOT
Offline Cuda_451
« Reply #18 on: March 24, 2016 - 10:34:27 PM »
How do I k ow if the trans is in park before I start it?
Offline 1 Wild R/T
« Reply #19 on: March 24, 2016 - 10:43:12 PM »
Does the driveshaft turn?   Yes?  Not in park.... No?  In Park.... :smilielol:   Shift lever all the way forward is park...  :thumbsup:
« Reply #20 on: March 24, 2016 - 10:48:35 PM »
             From the Service Manual (short version)
   Kickdown band adjustment  loosen jamb nut, run in adjuster then back out 2 1/2 turns.
   Linkage adjustment... With choke disconnected or held open have someone hold the kickdown lever on the tranny all the way forward (or make tool with spring to hold). Loosen kickdown lever adjustment bolt, holding the lever back, adjust the slotted bar forward till is in contact with the carb. stud.
« Reply #21 on: March 24, 2016 - 10:54:41 PM »
download the service manual here... might help to see/read it  http://www.mymopar.com/index.php?pid=109
Offline Cuda_451
« Reply #22 on: March 24, 2016 - 11:03:49 PM »
Thanks!
Offline Katfish
  • 70 Challenger
« Reply #23 on: March 25, 2016 - 06:18:48 AM »
But once again a small block... Just so the OP knows it the lever on small blocks has that hooked curve out the back of the trans, a big bock lever should come straight out....
Is this true for 904/727 & 318/340?
I think I have the wrong lever on mine, it's straight.
340/727
Offline 1 Wild R/T
« Reply #24 on: March 25, 2016 - 10:24:36 AM »
340/727
On a 727 small block I've seen both levers... If the linkage works properly leave it alone.. :2cents:
Offline Cuda_451
« Reply #25 on: March 25, 2016 - 12:00:47 PM »
Would a small block set up work on big block?
« Reply #26 on: March 25, 2016 - 12:39:55 PM »
they don't readily interchange.... hopefully the kickdown linkage came with the motor/tranny swap someone did...
Offline Cuda_451
« Reply #27 on: March 25, 2016 - 02:22:49 PM »
I sure hope so
Offline Cuda_451
« Reply #28 on: March 25, 2016 - 03:46:45 PM »
Can someone send me a picture of their linkage at the top of motor and by the trans?
« Reply #29 on: March 26, 2016 - 07:51:58 AM »
Problem is your 400 is not out of an e-body  & these linkages varied down through the years and by model..  you might Google 727 kickdown & look to see if anything looks familiar.
I found this b-body discussion about connecting to an Edelbrock carb    pictures attached but you have to download them to view... http://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/6581623/site_id/1#import
main pic I saw
