Author Topic: Front Shocks  (Read 5153 times)
Re: Front Shocks
« Reply #15 on: March 23, 2016 - 09:26:20 AM »
I'd get a compatible shock from the same source of the front  for the rear, ie another Stocker Star. If it were mine, I'd get a single adjustable so I could dial it up for street use and then dial it back for strip use.
No, mopars don't rock back in acceleration, they lift. The rear end should rise while stalling it in the lights, then when you let off the brake, the nose comes up to match. This is using the cars weight to leverage the tires into the pavement. If you have stock style Espos, the rise will be somewhat limited and the snubber, if the springs are working correctly, actually becomes ineffective unless you have a high stall convertor or four speed that is hitting the suspension hard at launch and twisting the springs.
Offline cudabob496
Re: Front Shocks
« Reply #16 on: March 23, 2016 - 04:49:11 PM »
I'd have to differ. Off the line, my Cuda rearend squats, and stays pushed down against my
adjustable pinion snubber, which plants the tires and prevents wheel hop.
2011 Kawasaki Z1000
Re: Front Shocks
« Reply #17 on: March 24, 2016 - 09:26:44 AM »
Okay. Every drag racing mopar I've had lifted, but if it works for you, stick with it.
Monroe makes a good shock for that. Not too expensive either. http://www.summitracing.com/parts/mon-66608/applications
Offline cudabob496
Re: Front Shocks
« Reply #18 on: March 24, 2016 - 02:22:14 PM »
I'm sure it depends on the setup, and I just drive on street, not at the drag strip.
2011 Kawasaki Z1000
Offline cudabob496
Re: Front Shocks
« Reply #19 on: March 25, 2016 - 05:12:16 PM »
put the QA1 shocks on the front. Big improvement is smoothness of ride.
Its like all the old bumps I use to drive on are gone. Gonna have to put
them on the back too. Guess I've been living in the stong age.
2011 Kawasaki Z1000
Offline cudabob496
Re: Front Shocks
« Reply #20 on: March 25, 2016 - 05:19:11 PM »
Jordan is spot on. when you say "just go in a straight line" is this a drag car? If so, get 90/10 or some other drag orientated shock, if however you have any intention on driving it on the street at all, get a good driving shock. I had KYBs on my Challenger, not impressed at all with them. Changed over to Bilstiens; awesome shocks. QA1s are well received but expensive.
which Bilstiens did you use on the rear?
2011 Kawasaki Z1000
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Front Shocks
« Reply #21 on: March 26, 2016 - 09:15:03 PM »
Offline cudabob496
Re: Front Shocks
« Reply #22 on: March 26, 2016 - 11:10:30 PM »
Just found this site with $95 Bilsteins!
https://www.performanceonline.com/1970-74-Dodge-Plymouth-Chrysler-Barracuda-Challenger-E-Body-Rear-Bilstein-Shock-Absorber/
Good to know. Wonder if they were meant or another car model though, since Bilstien does not seem to make one specifically
for a Cuda.
I may go with the QA1's, since they are 18 way adjustable, and I'm told I may need that adjustment option if I go with
the composite lightweight leaf springs from Hyperco.
2011 Kawasaki Z1000
Offline 70chall440
Re: Front Shocks
« Reply #23 on: March 27, 2016 - 02:20:12 PM »
for a Cuda.
I have them on my Cuda and Challenger; so I know they fit.
Current Mopar
Past Mopars
Offline dfrazz
Re: Front Shocks
« Reply #24 on: March 27, 2016 - 09:17:19 PM »
 :iagree:  B body and E body are the same for front as well.
Offline blown motor
Re: Front Shocks
« Reply #25 on: March 27, 2016 - 09:39:34 PM »
Are they also the same for the rear? The boxes mine came in had the right part number but they said Charger.
Offline cudabob496
Re: Front Shocks
« Reply #26 on: March 28, 2016 - 02:40:28 AM »
Bilstien needs to get their act together. They may be losing sales.
2011 Kawasaki Z1000
Offline dfrazz
Re: Front Shocks
« Reply #27 on: March 28, 2016 - 08:22:24 AM »
I am not sure, I would call Firm Feel or PST to verify.  This is the cheapest I have found so far, not sure about shipping though and PST has a coupon in their catalog.  https://www.performanceonline.com/Rear-Shock-Absorbers-Mopar/
