Author Topic: ring gear marking compound  (Read 579 times)
Offline john h
« on: March 23, 2016 - 09:30:29 AM »
Hi all,
just got my Diff back form the drive line shop.  I'm wondering if I should wipe down the marking compound before I install the diff?  would that compound possibly cause any lube issues or ring gear issues in the future if left on?  :dunno:
Thanks
John
John
73 Cuda
360 Crate motor
FiTech Fuel injection
727 Trans (wishing it had Over Drive)
Offline plumcrazzy
Re: ring gear marking compound
« Reply #1 on: March 23, 2016 - 08:46:49 PM »
If what you are referring to is the "bluing" that is used to check gear mesh then there should be no problem. If the material is a gear "lapping" type compound then it must go.  :ylsuper:
Offline john h
« Reply #2 on: March 23, 2016 - 09:00:08 PM »
its a yellow compound for checking The pattern.  its on about 5-6 tooth patterns in a bunch and in about 5 spots around the ring.
John
73 Cuda
360 Crate motor
Offline GoodysGotaCuda
« Reply #3 on: March 23, 2016 - 11:15:35 PM »
If it makes you feel better, clean it off...but it will not hurt anything at all.
« Last Edit: March 24, 2016 - 07:37:00 AM by GoodysGotaCuda »
1976 Dodge Warlock
Wheel & Tire Specs:Link
