Author Topic: 727 torque converter, replace flush etc.  (Read 935 times)
Offline culp71
« on: March 23, 2016 - 10:41:24 AM »
guys and gals,
I have a torque converter from a 71 727 Ebody 340.
my question is fluid looks clean and did not find any metal pieces,
but do you recommend to flush it, split it or simply replace it.
I would like to use it as it is the correct original.
do most replace, or have them rebuilt at a certified shop?
is to be put into a otherwise completely restored car.
« Last Edit: March 23, 2016 - 01:45:02 PM by culp71 »
Re: 727 torque converter, replace flush etc.
« Reply #1 on: March 23, 2016 - 08:40:31 PM »
It is now 45 years old , I would lean towards replacing it , do you know the history on it , have you run it before ?
Offline culp71
« Reply #2 on: March 24, 2016 - 11:09:07 AM »
I don't know the history,
I've never had it in a driving vehicle.. .
probably best to replace.
thanks.
« Reply #3 on: March 25, 2016 - 08:24:35 AM »
 :iagree:   The converter could be full of trash & distroy a new trans or the converter could just be damaged & not work properly anymore .
Offline YellowThumper
  • I left the snow for this?
« Reply #4 on: March 25, 2016 - 03:41:50 PM »
Replace because it is lower cost insurance for higher cost transmission
« Reply #5 on: March 25, 2016 - 06:14:07 PM »
He's running a 400 block... are those internally balanced?  Was a 71 340 internal or external balanced ?
« Reply #6 on: March 27, 2016 - 10:57:05 PM »
400 is external , 71 340 was internal
