Author Topic: 275/60/15  (Read 3217 times)
Offline polarbear123
275/60/15
« on: March 23, 2016 - 01:52:43 PM »
For you who are running 275/60.  What do you use for the front. When I bought my car it had 215/70/15.  Should I keep them or change and why?   I need new tires.
Offline 1 Wild R/T
Re: 275/60/15
« Reply #1 on: March 23, 2016 - 04:28:46 PM »
215/70-15  is  26.9" tall   6" tread  8.7 section width
275/60-15  is  28" tall   8.9 tread width  11" section width
Lots of guys use a 235/60-15
235/60-15  is  26.1" tall  8.1 tread width   9.5 section width
Offline cudabob496
Re: 275/60/15
« Reply #2 on: March 23, 2016 - 04:47:16 PM »
on back, Micky Thompson ET Streets, 275/50/15., on 8 by 15 Weld Prostars.  10 inch of tread on ground. about 11 inch section width,
and 26 inch dia
Front, Bridgestone, Ecopia low rolling resistence tires on 6 x 14 Prostars, about 25 inch dia,195/65-15.
These are also 10lb lighter each than my previous front tire. with these, wilwood brakes,
and the Welds, I shed 40 lbs off each front wheel.
« Last Edit: March 23, 2016 - 07:23:57 PM by cudabob496 »
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
Re: 275/60/15
« Reply #3 on: March 23, 2016 - 07:08:43 PM »
You can get 245s on the front but 235s will work as well.
Sometimes under extreme cornering you can rub the 245s.
Offline Those
Re: 275/60/15
« Reply #4 on: March 23, 2016 - 08:14:43 PM »
Using 225-70-16 on a 7inch rim on the front to keep the diameter close to the back.
Offline cudabob496
Re: 275/60/15
« Reply #5 on: March 24, 2016 - 12:37:43 AM »
you'll be quicker with a smaller front tire
2011 Kawasaki Z1000
Offline 1 Wild R/T
Re: 275/60/15
« Reply #6 on: March 24, 2016 - 01:18:39 AM »
If your that serious about drag racing you'd be better off with a lighter car than an E body.....    :2cents:
Offline cudabob496
Re: 275/60/15
« Reply #7 on: March 24, 2016 - 01:53:31 AM »
got it down to about 3250 lbs
2011 Kawasaki Z1000
Offline 1 Wild R/T
Re: 275/60/15
« Reply #8 on: March 24, 2016 - 02:00:43 AM »
And my buddy's 68 Valiant post is 2750...  Without working to hard at it...
Re: 275/60/15
« Reply #9 on: March 24, 2016 - 10:07:12 AM »
Thanks for the help.
Re: 275/60/15
« Reply #10 on: March 25, 2016 - 09:41:24 AM »
Mike, what do you want the car to do? Typically, taller and thinner tires are what drag racers and street racer want to use. Lower and wider tires provide a more stable footprint for better cornering ability and is more comfortable for use on the street.
Re: 275/60/15
« Reply #11 on: March 25, 2016 - 11:44:24 AM »
It is a street car only 500HP, 355 gears and it's a 4 speed.
Offline HP_Cuda
  • Mopar or No Car!
Re: 275/60/15
« Reply #12 on: March 25, 2016 - 02:02:07 PM »
If you can find them go with the 235's or 245's.
Re: 275/60/15
« Reply #13 on: March 25, 2016 - 02:49:08 PM »
If predominately street car, I'd go with a 235/60 and 275/60 combo. Produces a mild rake, but puts a fair amount of rubber in all four corners so you don't have to slow to a crawl for every street corner you go 'round. 235s are easy to find in multiple makes and are not awful expensive either. Most will be an S or T speed rating, so they are hugely grippy, but they are adequate for street purposes.
Offline Mopar Mitch
Re: 275/60/15
« Reply #14 on: March 29, 2016 - 03:32:05 PM »
For "street and HWY" crusing, I run BFG T/A 275-60-15 rear, and have recently stepped up a bit taller/wider for the front away from 245-60-15... now running 255-60-15 t/As... all on 15x8 mini-light rims... front/rear.   I like the slightly taller fronts so to give me a fraction(~1/4") more header clearance, as well as a slightly improved ride over any undesirable rough roads.... my suspension is set-up very stiff.. for handling purposes (AX/HSAX/HPDE)... and it handles/drives/rides fantastic!... especially on the highway as most enjoyable to "cruise"!
