Author Topic: 71 340 cuda muffler dimensions?  (Read 1878 times)
Offline culp71
« on: March 23, 2016 - 02:09:23 PM »
looking to see if someone has some info about the muffler for a 71 cuda.
not the resonators, but the mufflers (that sit on each side of fuel tank.)
diameter, length etc.
they appear to be round?
what is the length, and center or offset inlet?
I think the outlet must be off set and the opposite
has a hangar that mounts to bracket from trunk floor...
this will have the 'cuda exhaust tips that pass through rear valance.
looking to see if
http://www.ebay.com/itm/Walker-18179-Replacement-Muffler-/311536860961?fits=Model%3ACuda&hash=item48890b3f21:g:~RUAAOSwa-dWquZS&vxp=mtr
would work. looks correct but again unsure of what the dimensions should be.
thanks
« Last Edit: March 23, 2016 - 02:29:47 PM by culp71 »
Re: 71 340 cuda muffler dimensions?
« Reply #1 on: March 23, 2016 - 08:02:17 PM »
That's a smaller diameter pipe used on single exhaust /6 or 318.......I can get you #s on an OE muffler used on dual exhaust models if you still need
Offline CUDA JAS
  • vroooooom!
« Reply #2 on: March 24, 2016 - 09:02:18 AM »
I have a couple of mufflers sitting in my "inventory" for a future install.  I can take some pics and measurements tonight for you.
They are not factory mufflers, but should be very close.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline culp71
« Reply #3 on: March 24, 2016 - 09:10:44 AM »
ok that would be great, thanks CUDA JAS,
if that one is too small,(and I need the ones for 340 w dual), I think this one might work
(5 " round 19"  long)
http://www.ebay.com/itm/Walker-Direct-Fit-SoundFX-Muffler-18449/390989051649?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D35958%26meid%3D46ca4a20a29e4ca69bdbe49f73a0992d%26pid%3D100033%26rk%3D3%26rkt%3D4%26sd%3D311536860961
I'll compare to your info, thanks
« Last Edit: March 24, 2016 - 09:12:47 AM by culp71 »
Offline anlauto
« Reply #4 on: March 24, 2016 - 09:21:07 AM »
Why wouldn't you just buy the correct Cuda mufflers ? They are available through Accurate LTD ....
Offline culp71
« Reply #5 on: March 24, 2016 - 11:43:23 AM »
well....
I guess I did not know anyone had them,
I will also look into this, thanks anlauto
« Last Edit: March 28, 2016 - 11:51:16 AM by culp71 »
