Author Topic: Dash lights  (Read 5060 times)
Offline Cuda_451
Re: Dash lights
« Reply #30 on: March 26, 2016 - 11:14:12 PM »
Which fuse is it?
1970 Plymouth Barracuda
1995 Dodge RAM 1500 SLT
2006 Ford Mustang V6 Supercharged
Offline HP_Cuda
  • Mopar or No Car!
Re: Dash lights
« Reply #31 on: March 27, 2016 - 12:17:18 PM »
At this point, pull them all and check them all.
I did this to mine so I had a fresh fully functioning fuse block.
Fuses are cheap, my blood pressure is not.
Offline Cuda_451
Re: Dash lights
« Reply #32 on: March 27, 2016 - 01:59:15 PM »
I have all the light fixed except for the park lights but that's all close enough
Offline HP_Cuda
  • Mopar or No Car!
Re: Dash lights
« Reply #33 on: March 28, 2016 - 12:19:44 PM »
ughh thought he said marker lights.
« Last Edit: March 28, 2016 - 08:11:22 PM by HP_Cuda »
Offline Cuda_451
Re: Dash lights
« Reply #34 on: March 28, 2016 - 02:51:30 PM »
Turn signals work on them but where would the grounds be?
Re: Dash lights
« Reply #35 on: March 28, 2016 - 07:49:59 PM »
I can't see how grounds would be the issue as the same ground works for both tail lights & turn signals....
The tail lights circuit is a completely different system than turn signals up to the bulb getting power through the headlight switch on the unswitched side of the fuse panel while the turn signals only work when the ignion switch is on or turned to accessory.....
Offline HP_Cuda
  • Mopar or No Car!
Re: Dash lights
« Reply #36 on: March 28, 2016 - 07:55:14 PM »
Wait a min, you say your turn indicators work but your parking lights do not work?
See here:
http://www.mymopar.com/downloads/1970/70BarracudaA.JPG
« Last Edit: March 28, 2016 - 08:12:24 PM by HP_Cuda »
Re: Dash lights
« Reply #37 on: March 28, 2016 - 08:22:13 PM »
See here:
   HMMMMM ... Power to the headlight switch doesn't come through the fuse panel... one in-line fuse for the headlamps & taillights if I'm reading it right..
Offline Cuda_451
Re: Dash lights
« Reply #38 on: March 29, 2016 - 08:15:33 AM »
Yes, my front park lights are the only light not working right now. I have everything else working except them
Offline HP_Cuda
  • Mopar or No Car!
Re: Dash lights
« Reply #39 on: March 29, 2016 - 01:22:07 PM »
Yep doesn't look to go through the fuse block at all,  has to be a problem in the wiring.
Offline Cuda_451
Re: Dash lights
« Reply #40 on: March 29, 2016 - 03:00:20 PM »
Well crap
Offline lulurocks
Re: Dash lights
« Reply #41 on: March 29, 2016 - 04:44:09 PM »
question....
I don't have a cuda but I'm pretty sure the front sockets are a 2 pin  socket(1157 lamp)
If so ......with the light  bulbs  out do you have  12vdc   From one pin in the base of the socket  To  ground  when the parking lamp switch is on .
And with the hazards on you should have  flashing 12vdc  from the other pin to ground...
If it's not a 2 pin socket  I take back my entire post which I'm not responsible for  :bigsmile:
« Last Edit: March 29, 2016 - 05:21:30 PM by lulurocks »
Offline 70chall440
Re: Dash lights
« Reply #42 on: March 29, 2016 - 05:22:05 PM »
when you say they are not working, are you checking to see if there is power there or relying on the bulbs to light up? The wires go into the main lighting harness. where they terminate connect I would have to look at a wiring diagram to discern but they should not be hard to track.
Current Mopar
Past Mopars
