Author Topic: Chrysler Composite Monoleaf - Big weight savings  (Read 4483 times)
Offline cudabob496
2011 Kawasaki Z1000
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
Re: Chrysler Composite Monoleaf - Big weight savings
« Reply #1 on: March 23, 2016 - 07:38:30 PM »
I'll trust you after you report how awesome they are!
« Reply #2 on: March 23, 2016 - 07:44:32 PM »
I'm running them, very happy with them but be advised you WILL need good shocks ,something adjustable as they react much quicker than steel springs. I used double adjustable QA1 shocks.  I found 175 to lite might be ok for a SB  though? ( I'm using a BB) , I replaced them with 225 lb rate ( expensive mistake!) You will also require different spring hangers as the springs are not standard e-body length.
Offline cudabob496
« Reply #3 on: March 23, 2016 - 08:21:48 PM »
thanks. QA1 has an 18 way adjustable shock. Will that work?
2011 Kawasaki Z1000
Offline cudabob496
« Reply #4 on: March 23, 2016 - 08:24:58 PM »
so, if I ran the 175's, would i just be bouncing down the road? what does it mean to to be too light?
2011 Kawasaki Z1000
Offline cudabob496
« Reply #5 on: March 23, 2016 - 08:25:44 PM »
do you still have the 175s ?
2011 Kawasaki Z1000
Offline cudabob496
« Reply #6 on: March 23, 2016 - 10:19:30 PM »
don't trust me. do your research and trust yourself.
2011 Kawasaki Z1000
« Reply #7 on: March 23, 2016 - 10:24:18 PM »
Yep.
It depends on what torsion bars your using. I'm using 1.120 and have 1.180" yet to install . Corner weights will also effect your choices here. BB or SB?
No I sold them.
Offline cudabob496
« Reply #8 on: March 23, 2016 - 11:15:06 PM »
Yep. It depends on what torsion bars your using. I'm using 1.120 and have 1.180" yet to install . Corner weights will also effect your choices here. BB or SB?
No I sold them.
Looks like my torsion bars are about .95 inches. Probably what came with a 72 Cuda.
Is that a problem??
2011 Kawasaki Z1000
Offline cudabob496
« Reply #9 on: March 23, 2016 - 11:16:06 PM »
No I sold them.
Don't understand the subject of "corner weights"
2011 Kawasaki Z1000
« Reply #10 on: March 24, 2016 - 02:25:54 PM »
It's a balance thing, heavier springs are needed for heavier cars, front and rear weights also need to be balanced. Eg. 225 rear leaf springs wouldn't be favourable with /6 diameter torsion bars. ( Well unless the motor was mounted towards the rear enough  :D )  Driver preference is also a factor, me if having to choose  I prefer the rear end to be slightly loose over the front end pushing. Every E-Body pushes bad in stock form.  Shocks also play a big part. Handling is not just one thing it's the combination of parts chosen .
Offline wantone
« Reply #11 on: March 24, 2016 - 02:45:34 PM »
You're answer is my research hahaha.  You've got a cuda like I do.  I've only get the money to do it right the first time LOL
Offline cudabob496
« Reply #12 on: March 24, 2016 - 04:01:32 PM »
I see, I'm a guinea pig! A lab rat!  lol
2011 Kawasaki Z1000
Offline cudabob496
« Reply #13 on: March 24, 2016 - 04:04:11 PM »
OK, thanks, if I just drive in a straight line most the time, and floor it from the line, would you
still recommend the 225s over the 175s.  I found out Mopar heavy duty leafs are 160 lb/in.
2011 Kawasaki Z1000
« Reply #14 on: March 24, 2016 - 04:24:24 PM »
I'd say for what you want 175 or less ?  I'd question whether the weight savings is worth it in your case for the expense? Also your car will sit low, not up higher like a drag car usually does?   I've had 4 different sets of leaf springs on my car in 5 years "experimenting" that gets expensive....
