Author Topic: Ignition problems  (Read 1103 times)
Offline Cuda_451
Ignition problems
« on: March 23, 2016 - 08:38:16 PM »
I can start it manually from under the hood but it's dead when I try to start it with the ignition. Any idea?
1970 Plymouth Barracuda
1995 Dodge RAM 1500 SLT
2006 Ford Mustang V6 Supercharged
Re: Ignition problems
« Reply #1 on: March 23, 2016 - 08:48:43 PM »
Neutral safety switch?
Offline Cuda_451
« Reply #2 on: March 23, 2016 - 08:56:27 PM »
I done plugged it in and everything I'm confused on where a wire goes though. It's not the big plug in but a little one?
« Reply #4 on: March 23, 2016 - 09:04:06 PM »
Just ground the terminal on your relay that has a brown wire on it, then try to start. If it turns over, then your NSS, or NSS wiring is the problem.
Offline Cuda_451
« Reply #5 on: March 23, 2016 - 09:06:58 PM »
I'm just needing it to make it to prom for now so what's the worst that happens if I run it when it's grounded like that? How do I make sure that the linkages are set right?
« Reply #6 on: March 23, 2016 - 09:27:48 PM »
I'd think if your able to jump start it in Park and not get run over the linkage is OK...LOL   shorting the relay ground will allow the car to start in gear..  not a good thing  :eek2:
Two pieces of advice..
1. Learn how to use a multi-meter & read wiring diagrams if you don't already....
2. Do you & your date a favor n borrow someone's big Caddy or Lincoln for the prom..    :grinyes:
Offline Cuda_451
« Reply #7 on: March 23, 2016 - 09:47:28 PM »
I'll put rear end on jack stands just in case lol and no, all we ever had around my house is Mopars lol
Offline dougs bs23
« Reply #8 on: March 24, 2016 - 01:45:32 PM »
prom,,   wow,,  ah to be young and in lust   :roflsmiley:   rent a limo for the night   get a little woo hoo for the waa haa and youll get home safe
Offline YellowThumper
  • I left the snow for this?
« Reply #9 on: March 24, 2016 - 01:56:28 PM »
Unless of course the date is your sister.  But that info is definitely for another forum...
Good luck and let us know how it works out for ya. The car of course...
Offline Cuda_451
« Reply #10 on: March 24, 2016 - 02:44:10 PM »
Definitely not my sister lol worst comes to worst I'll just rent a challenger
