2 ways to do this , order or find a lean burn dist from the late 70s or early 80s , it has no advance mech .
If you want to use a dist with advance you can use an allen wrench & turn the srew inside the vacuum pot all the way CCW to the end this eliminates any movement there ,, weld up the slot in the mechanical advance plate under the pick up soit will still allow the pins into the plate but without movement ,, that will lock the upper shaft so it cannot move .
EFI with timing control is awesome , you can create any curve you want or need far more accurately
