Thanks N96!
Yours look great. Mine are repo louvers, I can slide them up to make the corners just touch the trim.
My problem is if I do this, I won't be able to install and use the hood pin & clip that goes on bottom. You can see this in my 2nd pic.
The fact I have the SE plug in there makes it difficult to see where the normal bottom should be.
By any chance, do you have a close-up pic of the bottom where the louver slides into the hold down pin?
Thanks
