OK, so the project has been going pretty well thanks in part to a lot of information I have gathered from our web site. I must have a whole scrapbook on door and side glass installation and I am still dreading it. But not there yet. I am in the process of installing the steering column and can't find the roll pin. Does anyone out there know the size I need for the coupler at the bottom of the shaft. I think they are all the same but it is manual steering if that makes a difference. I also forgot about the plug end I needed for the column wiring. It is the one with the big red wire in it. Mine has been cut and bypassed the connector due to burnout. It is the first picture below. I have been looking at all my mopar sources and have come up empty. Are these connectors and pins reproduced. My connector is real bad I don't think I can save it. The last item is the exhaust. I am having a problem installing the T/A exhaust. Is there a sequence to install it to make it easier? Thanks in advance. Enjoy the rest of the pictures.
