New to the club........
Author Topic: New to the club........  (Read 4553 times)
Offline Christian
« on: March 26, 2016 - 09:30:02 PM »
my name is Christian, just bought a beautiful 1970 Challenger to share garage space with my 66 GTO, hope to have it home in a few weeks, here are the specs/build
 1970 DODGE CHALLENGER
This car was featured in Popular Hot Rodding Magazine and was built by South Coast Rides in Texas. The car received a full rotisserie restoration with the underside as nice as the top. The 416 stroker small block was built by Hughes Engines in Illinois and made 555 hp at 6,100 rpm and 552 lb-ft at 4,600 rpm while carbureted. The engine has since been converted to fuel injection. The car was previously equipped with an air ride suspension but that has since been removed for a QA1 coil over setup on all 4 corners. This is a well-sorted pro touring style car that goes as good as it looks.
email me for additional info - Shipping can be arranged easily as this is originally a US vehicle.
ENGINE
Type: Chrysler 416ci small-block
Block: Chrysler block, bored to 4.080 inches
Oiling: Melling high-volume oil pump, Milodon pan
Rotating assembly: Mopar Performance 4.000-inch steel crank, Scat H-beam rods, Keith Black 9.3:1 forged pistons
Cylinder heads: ported Edelbrock Performer RPM aluminum castings with 2.08/1.60-inch valves; Hughes springs and retainers
Camshaft: Hughes 242/246-at-.050 hydraulic flat-tappet cam, .592/.606-inch lift, 110-degree LSA
Valvetrain: Hughes lifters, 1.6:1 rockers, and timing set
Induction: ported Edelbrock Victor intake manifold, FAST XFI Fuel Injection
Ignition: FAST billet distributor, 6AL ignition box, coil, and plug wires
Fuel system: Rick's Hot Rod Shop tank; Aeromotive in-tank pump and regulator
Exhaust: TTI Performance 1¾-inch long-tube headers and X-pipe, dual 2.5-inch DynoMax mufflers
Cooling: Mopar Performance pump; Be Cool radiator and dual electric fans
Output: 555 hp at 6,100 rpm and 552 lb-ft at 4,600 rpm
Built by: Hughes Engines (Washington, IL)
DRIVETRAIN
Transmission: Phoenix GM 4L60E overdrive, adapter plate, custom flexplate, and 3,000-stall coverter; Compushift computer, Lokar shifter
Rear axle: Chrysler 8 3/4-inch rearend, Auburn limited-slip differential; Moser 30-spline axles and 3.70:1 gears
CHASSIS
Front suspension: Ridetech tubular control arms, QA1 Coil overs; stock sway bar
Rear Suspension: Ridetech four-link, QA1 Coil overs, and subframe connectors
Brakes: Baer 13-inch discs with two-piston calipers, front and rear
WHEELS & TIRES
Wheels: Boze Pro Touring 18x8 (4.5-inch backspace), front; 18x10 (5.75-inch backspace), rear
Tires: Goodyear Eagle F1 225/45R18, front; 295/45R18, rear
1970 Challenger http://i65.photobucket.com/albums/h238/90_Shelby/Challenger/IMG_0712.jpg
1966 GTO
http://i1006.photobucket.com/albums/af182/christian121069/Mobile%20Uploads/2015-03/2015-11/1CE85973-CD27-42E5-B867-886712028C80.jpg
1966 GTO I'll do my best to accurately describe this Goat.
This is a 1966 Pontiac GTO that is anything but stock with only around 10,000 miles since being finished.
it has had a complete frame off restoration to start.
Everything was blasted down to bare metal and anything that needed to be was repaired with metal.
To call this paint job glass is an understatement.
The original motor was pulled to make way for a Fuel Injected ZZ502 crate motor, backed up with a t-56 designed for the Dodge Viper.
Every interior piece was either replaced or refurbished.
It has ice cold vintage AC.
The suspension is Coil overs up front, with airbags in the back.
It used to be full airbags, but for performance the coilovers were added up front.
Disc brakes are on every corner.
American Racing Torque Thrusts 18"s in the back and 17"s in the front t add to the stance, but we also have the proper offset 18"s for the front if thats the look that is desired.
This car runs and drives amazing.
It is just loud enough with no drone.
Fast and smooth, not to mention reliable.
This car has been on countless cruises, car shows and even easily survived 2 Hot Rod Power Tours.
This car has had more money thrown at it than you can imagine, and will obviously be offered at much less than the cost of the build.
It does have some minor flaw, chips etc, as it was driven, but surely nothing substantial.
Overall this is a outstanding car that is as at home at the concourse as it is on the open road.
« Last Edit: March 26, 2016 - 09:36:33 PM by Christian »
2015 Porsche Macan Turbo (white)
2012 Porsche 997.2 Twin Turbo (white)
1996 Porsche 993 Twin Turbo (guards red)
1968 Porsche 911 (sand beige)
1970 Dodge Challenger (b5 blue)
1966 Pontiac GTO (light blue)
1966 Fastback (black)
Re: New to the club........
« Reply #1 on: March 26, 2016 - 10:12:02 PM »
Welcome, I remember your car in the magazine. Nice ride!  :2thumbs:
Offline jimynick
« Reply #2 on: March 26, 2016 - 10:44:44 PM »
Welcome to the site. Are you a muscle car salesman?  :wave:
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #3 on: March 26, 2016 - 10:47:19 PM »
Welcome from CO!  You are gonna love that 416!
Offline Christian
« Reply #4 on: March 26, 2016 - 11:09:36 PM »
not at all, just an enthusiast.  i am into Porsches as well.  also have a 2012 997.2 twin turbo, 1996 993 twin turbo and a 1968 911.  Also have a Porsche Macan Turbo as a DD
Offline Christian
« Reply #5 on: March 26, 2016 - 11:10:39 PM »
Hope so, the wait is killing me, its coming from Canada so its been a PITA to say the least
Offline blown motor
« Reply #6 on: March 27, 2016 - 07:54:34 PM »
Offline 69ChargerRT
  • Its the car, right? Chicks love the car. - Batman
    • Daisy - My 1969 Dodge Charger R/T
« Reply #7 on: March 28, 2016 - 10:46:03 AM »
great looking car you bought!  post more pictures when you take delivery!
Offline onebadfish
« Reply #8 on: March 28, 2016 - 10:57:13 AM »
Wow sounds very very nice - post some pics soon!
Offline 734406pk
  • Andy
« Reply #9 on: March 28, 2016 - 07:10:46 PM »
Welcome to the site! Very nice cars you have in your collection! Enjoy your Challenger! :2thumbs:
Offline Christian
« Reply #10 on: March 30, 2016 - 09:16:37 PM »
thanks fellas.  the car is being picked up tonite in canada, should be 10-14 days and it will be in my garage, very excited
Offline Christian
« Reply #11 on: April 16, 2016 - 10:16:48 AM »
car is scheduled for delivery today, very pumped :bananasmi :ylsuper:
Offline js29no
« Reply #12 on: April 16, 2016 - 10:47:24 AM »
Welcome and enjoy! :2thumbs:
« Reply #13 on: April 16, 2016 - 06:12:02 PM »
Enjoy I hope you enjoy it!  :2thumbs: :burnout:
Offline Christian
« Reply #14 on: April 17, 2016 - 08:52:54 PM »
car is in the garage, it is bada55. loving the mopar.  the 416 stroker is a beast, pics later in the week
