Author Topic: cuda front and rear window clip correct location...  (Read 968 times)
Offline culp71
« on: March 28, 2016 - 11:33:59 AM »
hello all,
went to put in front and rear windows this weekend but stopped just before, at the concern of the window trim clip placement.. I have all original holes but uncertain on rear window which ones receive these "hold up" brackets, and if one should bent the tab V cut part up that is slightly bent inside these brackets, and on front if anything other then clips around sides & top and the spacers on bottom, if anything else should be installed before glass is set in?
any help and pics would be great, 70 cuda...
also wondering on rear window does the window sit against these "hold up" clips, or should there be some sort of cushion between the glass edge and the alignment clip.
as I noticed the front windshield glass edge sits against the rubber spacer.
« Last Edit: March 30, 2016 - 08:57:21 AM by culp71 »
Offline culp71
Re: cuda front and rear window clip correct location...
« Reply #1 on: March 31, 2016 - 11:12:25 AM »
so here's the rear hold up clip, see the arrow, the stamped piece appears to have this part slightly flared up, should one bent this up further, as I see it aligns with the rear glass is it to be used for holding bottom of window in, or just up.
does this hold up clip get a cushion between it and the bottom edge of glass, or does glass rest against this metal piece?
thanks
Offline culp71
« Reply #2 on: April 13, 2016 - 09:12:28 AM »
so I installed these clips to what made sense to me for all these trim clips, the one concern is the rear top outside corners, there are two holes relatively closer to each other then the rest of the layout, wondering if both of these need clips or just the inner or outer hole?
« Last Edit: April 13, 2016 - 11:58:33 AM by culp71 »
