News:
Nice build! I'm doing about the same with my Challenger but your'e moving with 10x my speed What are you gonna do for AC? I see you left the stock holes. I got a Vinatge Air kit and I thinking about welding up them, or possible use one of the oval hose holes for the Hemi harness, if that is possible locationwise.
After a little while on hold,the work has started again.The engine bay have been painted a second time since the first try came out a little to glossy, it's now painted with Glasurit "Rallye schwarz" and it looks so much better.Guess its time to put in the engine now
I agree, the engine bay looks really clean! Question on your dual fans with shroud: It seems to me that blocking that much air flow would negatively impact the ability for the fluid to cool in the radiator. Is the theory that the shroud actually helps the air suck better through the fans despite blocking so much of the radiator?
Did you cringe when sliding the clip nuts onto the freshly painted inner fenders? I always wonder about fasteners scraping off paint... I suppose there is no avoiding some of that. Is there a trick you use when installing them?
That paint looks great. I see you are keeping the battery in the stock position, I wanna do that also, what are you gonna do with the airfilter?
