Author Topic: Where is the best place to mount elec fuel pump  (Read 5596 times)
Offline HP_Cuda
  • Mopar or No Car!
Re: Where is the best place to mount elec fuel pump
« Reply #15 on: April 04, 2016 - 12:51:00 PM »
Maybe this will give you some inspiration...
Offline Lbs
« Reply #16 on: April 04, 2016 - 05:36:23 PM »
That looks sweet HP........nice and clean. It's fun working under these cars when the bottoms in as good of shape as the top. Did you have to do something to be able to mount it above the tank like that?? Mine said it was recommended to mount it below the fluid line so I made a bracket to get it down there. :dunno what the purpose of that is so I just did what they said.
Sent from my iPad using Tapatalk
Offline YellowThumper
  • I left the snow for this?
« Reply #17 on: April 04, 2016 - 08:11:29 PM »
Pumps are designed to pump. Not so good at sucking when pump is above tank. Also pump mounted up high should have an anti back flow valve to prevent pump from draining back to tank when shut off.
Offline Lbs
« Reply #18 on: April 04, 2016 - 10:00:08 PM »
Ahhhhh! So I probably did the right thing building a bracket????
Sent from my SM-N920V using Tapatalk
Offline dougs bs23
« Reply #19 on: April 04, 2016 - 10:25:17 PM »
 Is that a Mallory pump.  How's the noise level.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #20 on: April 05, 2016 - 10:01:26 AM »
I used a Mallory 4110 on my '71 Challenger mounted near the fuel tank like HP.  It is by far the quietest pump out there and runs like a champ!
Offline HP_Cuda
  • Mopar or No Car!
« Reply #21 on: April 05, 2016 - 03:41:02 PM »
It's the best pump by far for performance and noise bar none. Try doing this with either a red or blue holley pump - whoa very noisy.
I don't have any problems where it's mounted but you can mount it lower with a bracket if you like, I don't think necessary but ymmv. I only have to have the pump run for about 3 seconds before starting the motor - and starts fast every time.
