Author Topic: Dougs Headers and a 727 trans  (Read 2229 times)
Offline shatar4
  • 71 Challenger
« on: March 29, 2016 - 08:07:45 AM »
Just installed a 440 and was hooking up the 727 trans. Ran into a problem that has me baffled. The lower rod that connects the shifter  to the trans is hitting the collector on the header. Has anyone ran into this problem? What else can be done besides a cable use shifter? I am useing the D452 headers.
1971 Triple black 340 Challenger
Offline 73_Cuda_4_Me
Re: Dougs Headers and a 727 trans
« Reply #1 on: March 29, 2016 - 08:21:33 AM »
If it is a column shift, there are larger offset shift bell-cranks available from header manufacturers (they will specify them in 'requires item...' in application info), or you can make one of your own like I did on my 340 with 727... original was contacting collector like you describe... here is a pic of what I made... not sure about floor shift mods...
« Last Edit: March 29, 2016 - 08:23:51 AM by 73_Cuda_4_Me »
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline shatar4
  • 71 Challenger
« Reply #2 on: March 29, 2016 - 08:26:38 AM »
Mines a floor shift but that gives me an idea what I might have to do. Thanks
« Last Edit: March 29, 2016 - 08:31:14 AM by shatar4 »
Offline bandt
« Reply #3 on: March 29, 2016 - 12:10:48 PM »
Just flip the linkage around that goes to the torque shaft. It goes to the top instead of bottem
Offline Fern
« Reply #4 on: March 29, 2016 - 06:41:49 PM »
Unrelated question. Do you have fast ratio arms?
If you do , did the headers fit without mods?
If you don't can you measure how much clearance you have between the pitman and idler arms to the header?
Thanks, this might answer questions on another topic.
« Reply #5 on: April 19, 2016 - 04:57:47 PM »
One quick question for the Doug's installers... I am getting ready to pull the trigger on purchasing a set, but they say you need a mini-starter? Is it possible to use a stock starter with 727 column shift????
Thanks in advance, and sorry for the hi-jack.. It's in the same category, though!  8  )
R11 V6X EN2
« Reply #6 on: April 19, 2016 - 10:30:33 PM »
Note to self (and others here)... PerTronix Tech support email says "YES!", mini-starter is required...
R11 V6X EN2
