Author Topic: cuda glass install  (Read 1159 times)
Offline culp71
cuda glass install
« on: March 30, 2016 - 03:45:13 PM »
went to put in front and rear windows this weekend but stopped just before, at the concern of the window trim clip placement.. I have all original holes but uncertain on rear window which ones receive these "hold up" brackets, and if one should bent the tab V cut part up that is slightly bent inside these brackets, and on front if anything other then clips around sides & top and the spacers on bottom, if anything else should be installed before glass is set in?
any help and pics would be great, 70 cuda...
also wondering on rear window does the window sit against these "hold up" clips, or should there be some sort of cushion between the glass edge and the alignment clip, since noticed the front windshield glass edge sits against the rubber spacer.
Offline culp71
Re: cuda glass install
« Reply #1 on: March 31, 2016 - 11:12:49 AM »
so here's the rear hold up clip, see the arrow, the stamped piece appears to have this part slightly flared up, should one bent this up further, as I see it aligns with the rear glass is it to be used for holding bottom of window in, or does this flare dig into a cushion of some sort to keep it in place?
does this hold up clip get a cushion between it and the bottom edge of glass, or does glass rest against this metal piece?
which holes do these hold up clips go in, bottom corners, second hole, third? etc.
thanks
« Last Edit: April 01, 2016 - 08:15:47 AM by culp71 »
Offline AARTA340
« Reply #2 on: March 31, 2016 - 01:12:45 PM »
 :popcorn:
Offline culp71
« Reply #3 on: April 01, 2016 - 02:01:38 PM »
please...
anyone...
i've even resorted to a simple "Google" search for help and have yet to piece it all together.
This is holding up progress.....hoped to complete glass install this weekend.
help!
 :faint:
Offline c4orce
« Reply #4 on: April 01, 2016 - 02:09:48 PM »
Try a search on google for  "power nation:Detroit muscle-pain in the glass" they install Windows in 70 challenger...maybe that will help
Offline culp71
« Reply #5 on: April 01, 2016 - 03:07:44 PM »
thanks for the tip, but I just watched it and it was no help.
I need to know clip and alignment clip placement and direction, spacer setup for front and rear windows
ill keep looking..
« Last Edit: April 01, 2016 - 03:32:47 PM by culp71 »
Offline culp71
« Reply #6 on: April 01, 2016 - 03:09:05 PM »
I've even looked through different episodes of "graveyard cars" just to see it I can find a screen shot
that shows the clip placement and direction and spacers...nothing so far
also been looking at ebay , etc for used cuda's for sale to see if one has untouched clips so I can determine where and what the setup should be......
 :pullinghair:
« Last Edit: April 01, 2016 - 03:47:00 PM by culp71 »
