Author Topic: Will a 130 tooth flywheel and 10.5 clutch work with a factory 11" bellhousing?  (Read 551 times)
Offline KillerBee
Thinking of replacing my 143 tooth flywheel and 11" clutch setup with a 10.5" clutch and 130 tooth flywheel.
Can I use my current factory bellhousing which is setup for the bigger clutch and flywheel or do I need a new/different bellhousing setup for the 10.5" parts?
Thanks.
You will need a different belhousing for the 130 tooth flywheel it is smaller in diameter & the stater will not engage the teeth on the 130 flywheel
Offline KillerBee
Thanks.
