Author Topic: HELP lost all electrical power inside the car  (Read 4004 times)
Offline GreenFish
« on: April 03, 2016 - 12:59:24 PM »
as the title states. i have no power inside the car. I noticed it today when i went to do some trouble shooting for my wiper switch. i have 12v at the starter relay, i have 12v at the end of the harness on the firewall. the starter will jump if cross it. my battery is charged.
but no dome light, and no ignition switch and as far as i can tell nothing else either. I put a test light on the fuse panel at different fuses and nothing. i dont see any obvious blown fuses.
ideas??
caveat: I ve been messing with things such as the wiper switch so the whole left panel is out. But that shoulnt affect the ignition switch right??
« Last Edit: April 03, 2016 - 01:03:36 PM by GreenFish »
Re: HELP lost all electrical power inside the car
« Reply #1 on: April 03, 2016 - 01:13:22 PM »
Check the bulkhead connection, heavy red wire....
Offline shawge
  • Zoiks!!
« Reply #2 on: April 03, 2016 - 01:13:34 PM »
So you are getting 12v outside of the cabin but not in?  Have you tested the bulkhead connections for voltage?  IIRC, you were removing/replacing/re-purposing wiring for the MS install, perhaps something is not making a connection now.
Edit: Bah, got treed by Brad :)
- Jerry
Offline GreenFish
« Reply #3 on: April 03, 2016 - 01:44:10 PM »
you mean from inside the car? let me go check
« Reply #4 on: April 03, 2016 - 01:49:19 PM »
Under the hood. It's a plug in, common trouble spot. Connectors corrode and burn up in bad cases.
Offline GreenFish
« Reply #5 on: April 03, 2016 - 01:52:06 PM »
I have 12v inside opposite the bulkhead connector behind the fuse panel
« Reply #6 on: April 03, 2016 - 02:13:24 PM »
Ignition switch?  :dunno:
Offline GreenFish
« Reply #7 on: April 03, 2016 - 02:14:22 PM »
wouldnt I have a dome light at least if it was an ignition switch?
Offline polarbear123
« Reply #8 on: April 03, 2016 - 02:31:15 PM »
Wire coming down cloumn into plug under dash
« Reply #9 on: April 03, 2016 - 02:31:37 PM »
Look at this e-bay auction, notice the 3rd picture, see how the red wire in the plug is burnt.
http://www.ebay.com/itm/Non-Rallye-Dash-Wiring-Harness-1970-71-E-Body-cuda-challenger-/111942172404
Offline YellowThumper
  • I left the snow for this?
« Reply #10 on: April 03, 2016 - 02:40:06 PM »
Do you still have the full power amp gauge hooked up?
I would look into that because if it burned out plenty of power would be dead.
Are all of your recent addons powered thru the factory harness?
Offline GreenFish
« Reply #11 on: April 03, 2016 - 02:40:31 PM »
I Have nothing at all right now, No headlights, tail lights, dome light, ignition, nothing...  It's dead in the water
I have power at the bulk head connector inside the cabin. I have no hot fuses
Offline GreenFish
« Reply #12 on: April 03, 2016 - 02:42:20 PM »
I swapped the amp gauge for a volt gauge. I am switching to a one wire alt so I changed it out. All i did was switch the gauge out and used the same + and - wires that the amp gauge was connected to. Did I mess something up?
no all new add ons are using a separate fuse panel and relays on its own switch
« Last Edit: April 03, 2016 - 02:44:07 PM by GreenFish »
Offline GreenFish
« Reply #13 on: April 03, 2016 - 02:49:28 PM »
i put my dash back together just to be sure , still nothing. How can i have lost all power? Something must have blown??
Offline GreenFish
« Reply #14 on: April 03, 2016 - 02:51:03 PM »
yes i found that wire at the bulk head inside. IT has 12v hot.
