Author Topic: HELP lost all electrical power inside the car  (Read 4007 times)
Re: HELP lost all electrical power inside the car
« Reply #15 on: April 03, 2016 - 02:59:03 PM »
ammeter issue? , is it bypassed?
Offline GreenFish
« Reply #16 on: April 03, 2016 - 03:05:02 PM »
Ok, I'm a dumb ass. .. so evidently you can't just swap the ammeter for a volt meter. Took out the volt meter and connect the two wire and the dome light came on... what a relief
Sent from my SM-G920V using Tapatalk
Offline GreenFish
« Reply #17 on: April 03, 2016 - 03:13:33 PM »
Thanks for the help guys
« Reply #18 on: April 03, 2016 - 04:06:12 PM »
 :clapping: :2thumbs:  Glad you found it!
Offline YellowThumper
  • I left the snow for this?
« Reply #19 on: April 03, 2016 - 06:13:05 PM »
I swapped the amp gauge for a volt gauge. I am switching to a one wire alt so I changed it out. All i did was switch the gauge out and used the same + and - wires that the amp gauge was connected to. Did I mess something up?
no all new add ons are using a separate fuse panel and relays on its own switch
Bypassed the amp? And added the volt or is the power going thru the volt gauge?
« Reply #20 on: April 03, 2016 - 06:39:53 PM »
Hmmm. That would not work. Connect both wires that were on your amp gauge to the +ve post on your volt gauge, then connect the other post of your volt meter to ground. You will then be good.
Offline GreenFish
« Reply #21 on: April 04, 2016 - 06:57:09 AM »
yeah i bypassed the amp gauge and viola it all came back on. clearly I did not wire my volt gauge right. thanks for the help
« Reply #22 on: April 04, 2016 - 12:14:30 PM »
 :2thumbs:
Offline msbaugh
« Reply #23 on: April 04, 2016 - 12:48:17 PM »
Voltage = wired in parallel
Current = wired in series
Just like when you're using your multimeter
Also,I would put the voltmeter on switched power not the wire previously used on the ammeter gauge
Offline GreenFish
« Reply #24 on: April 05, 2016 - 11:07:32 AM »
Thanks, yeah after this little lesson I did some looking up on the intewebs and found pretty much what you just told me. Perhaps I should have done that first.  :dunno:
« Reply #25 on: April 05, 2016 - 01:16:57 PM »
Just returning the help...
