Author Topic: Budget Suspension/Brakes kit for 71 cuda  (Read 1376 times)
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
« on: April 04, 2016 - 02:53:30 PM »
Howdy - Looks like my motor is from a 69 b body as my K member has holes flanking the oil pan.
My question is - does anybody have any idea on what suspension / brake kit could be sourced relatively inexpensively?  I'm looking to keep the k=member or get the correct one... either way.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Budget Suspension/Brakes kit for 71 cuda
« Reply #1 on: April 04, 2016 - 03:44:35 PM »
What are you starting with?  71-74 have the same front spindles so you can pick up a MC, rotor and caliper at NAPA and will need a distro block and brake booster if you don't have that, along with brake lines.  I got the Stage III kit from Dr. Diff for my '68 Charger.
For suspension, again what are you starting with?  Do you need everything?
Offline CUDA JAS
  • vroooooom!
« Reply #2 on: April 04, 2016 - 03:58:30 PM »
and what are your goals with eh car...street cruiser, drag racer??
Overall I think we just need more info.
Jason
74 'cuda 360/727
Just call me a gearhead!
« Reply #3 on: April 04, 2016 - 04:03:10 PM »
Rebuild front end with good bushings
get a good alignment
replace brakes with new parts (use good pads)
replace shocks with goods ones (Bilsteins)
review Mopar Action articles on modifying the PS
upgrade or add a front sway bar
Offline wantone
« Reply #4 on: April 04, 2016 - 05:25:02 PM »
Thanks for all the feedback - i've got a street cruiser with a k-member from a latter 60's (69?) Kmember.   I believe the front disc setup is OEM correct size.  My shocks are pieces of caca and i have old leafs in back with drums in back.   My brakes have a new booster with disc/drum MC.
Offline dfrazz
« Reply #5 on: April 05, 2016 - 10:09:16 AM »
So you already have front discs?  Do you need to just replace the rotors and calipers?  If so, just call NAPA.  If you need a new set up, call Dr Diff and do it right.
Bilsteins are the best shock for the money.  You could always go with Monroe's if you are on a tight budget but they are crap in the long run.
I agree with 70chall440, Moog suspension kit from PST is the way to go and get offset UCA bushings to help with camber/caster when you get an alignment.
Suspension and brakes are the foundation of everything and very important for safety.  Don't skimp, do it once and do it right.
Offline wantone
« Reply #6 on: April 05, 2016 - 10:46:52 AM »
Good stuff here thanks~!  :thinkerg:
