Author Topic: Door Lock Assemblies 71 cuda  (Read 1076 times)
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
« on: April 06, 2016 - 12:35:47 PM »
Hi!
Both of my door lock assemblies (driver side and passenger) don't work.
Driver side: Key goes into lock and barrel swivels 360'.   What the heck?
Passenger side: Key goes in and swivels 90' left and 90' right. What the heck?
Neither can engage or disengage the locks.
Need a video or install diagram and maybe a little guidance thanks!!!! :feedback:
Want one?  Got one! ... finally
Offline anlauto
Re: Door Lock Assemblies 71 cuda
« Reply #1 on: April 06, 2016 - 12:36:36 PM »
Is there rods attached to them ?
Offline wantone
« Reply #2 on: April 06, 2016 - 01:58:47 PM »
Have not opened the door panel yet.
Offline lulurocks
« Reply #3 on: April 06, 2016 - 01:59:19 PM »
 :iagree:     with Alan
one may have no rod , one may be out of adjustment.
if one is attached there is a  cam inside that  lines up with the lock weight cam . if it is out of adjustment it wont lock.     look above the door latch there is a 1/4 access hole to get to the cam adjuster, allenhead set screw , but you need the door panel off to correctly set it .
sounds like you need to take the door panels off anyway.
« Last Edit: April 06, 2016 - 02:01:02 PM by lulurocks »
Offline lulurocks
« Reply #4 on: April 06, 2016 - 06:17:36 PM »
As said. Before make sure your rods are attached , lubed and free working , on that's stuck will jam up the works also, here's some pics I had of the latch..
I don't guarantee the content of this message it's what the voices in my head told me to type :droolingbounce:
How the lock  and handle rods layot
How the  cams are supposed to be lined up when latch is locked:
Allen bolt that's adjusted by the hole in the door  above the latch, loose it  and move the linkage  so the cams line up when in the locked position.
« Last Edit: April 06, 2016 - 06:52:22 PM by lulurocks »
