Author Topic: Vacuum  (Read 1001 times)
Offline 4Cruizn
  • HEMI FISH
Vacuum
« on: April 06, 2016 - 04:17:25 PM »
What is the needed amount of vacuum to properly operate the braking system for a stock 440 with power brakes? :clueless:  I assume you measure this at an idle . . .
« Last Edit: May 20, 2016 - 11:57:56 PM by 4Cruizn »
Offline HP_Cuda
  • Mopar or No Car!
Re: Vacuum
« Reply #1 on: April 06, 2016 - 04:25:09 PM »
12" and higher would be optimal, once you get into bigger cams and that number drops you need to either look at vacuum canisters to help boost that or go a different route.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Vacuum
« Reply #2 on: April 06, 2016 - 05:06:41 PM »
Do you have a dual diaphragm booster?
If you don't have enough vacuum I would highly suggest going with hydraulic set up instead of a vacuum pump.  They are obnoxiously loud.
Offline 4Cruizn
  • HEMI FISH
Re: Vacuum
« Reply #3 on: April 08, 2016 - 10:57:49 PM »
Ok please explain?    :dunno:
Re: Vacuum
« Reply #4 on: April 08, 2016 - 11:24:24 PM »
Regular booster 12" diameter 3" thick
Dual diaphragm 8 " diameter 6" thick
Offline cudabob496
Re: Vacuum
« Reply #5 on: April 12, 2016 - 09:04:27 PM »
I added an additional vacuum canister, because I was at 10 inches at idle
2011 Kawasaki Z1000
