Do you have a pilot bushing inserted in the end of the crankshaft? Some engines that had the 727 mounted to them didn't have the hole drilled in the crank, so if there is no hole, the tranny won't go all the way home. If you do have the hole and pilot bushing, if there is a ding on the bushing, it's enough to hang up the input shaft.
