Author Topic: Two questions re brake pedal  (Read 1528 times)
Offline usraptr
« on: April 08, 2016 - 10:31:54 AM »
When I took my brake and clutch pedal assembly apart to restore it there was a spring on the brake pedal.  Naturally, even though I took several pictures of the assembly before I took it apart, I didn't get a picture of how the spring attached to the  brake pedal and now I can't figure it out.  The manual doesn't show it and I haven't been able to find a picture of it anywhere.  Can somebody explain how this spring attaches to the brake pedal or better yet  have a picture of how this spring attaches to the brake pedal they can share?
Second question, as you can see by the attached picture, my brake pedal sits lower than the clutch pedal.  Granted, while the pedal is connected to the power booster, neither the master cylinder or the above mentioned spring are installed yet so I don't know if that will make any difference.  The power booster was rebuilt so I don't know if maybe the shaft on the back of the booster isn't adjusted properly??  Also, the clutch pedal isn't connected to anything except the large return spring so maybe it's too high until connected accounting for the difference is pedal heights??? :clueless:
Any help or suggestions would be greatly appreciated.
(Edited 8-1-17)
Re: Two questions re brake pedal
« Reply #1 on: April 08, 2016 - 10:52:02 AM »
 the different height is normal , the clutch pedal has to have a longer throw , newer cars are designed better with the pedals more even  I wish at least the gas & brake were at the same height
« Last Edit: April 09, 2016 - 09:15:30 PM by Chryco Psycho »
Offline shawge
  • Zoiks!!
« Reply #2 on: April 08, 2016 - 11:41:03 AM »
 :dunno: My car originally had power brakes and there was a spring from a groove in part of the bellcrank to the top of the assembly frame.  I'll look for a picture...
- Jerry
Offline shawge
  • Zoiks!!
« Reply #3 on: April 08, 2016 - 11:46:29 AM »
Here it is...
- Jerry
Offline YellowThumper
  • I left the snow for this?
« Reply #4 on: April 08, 2016 - 01:08:47 PM »
Here it is...
Yep x2
My assumption is because of the ease of pedal movement with the power setup it is there to "neutralize" the dead weight of the pedal.
« Last Edit: April 08, 2016 - 01:11:03 PM by YellowThumper »
Offline usraptr
« Reply #5 on: April 09, 2016 - 11:35:07 AM »
Thank you Shawge for the picture, that helps a lot.     :ylsuper:  Also thanks Chryco for the explanation on the pedal heights.  :2thumbs:
(Edited 8-1-17)
Offline anlauto
« Reply #6 on: April 09, 2016 - 11:42:46 AM »
YES...power brake cars got that spring to hold the lever system.
