Author Topic: Using a push button to start?? how to wire?  (Read 4935 times)
Offline 70chall440
Re: Using a push button to start?? how to wire?
« Reply #15 on: April 11, 2016 - 09:41:26 PM »
Here you are
Current Mopar
Past Mopars
Offline Mpdlawdog
« Reply #16 on: April 12, 2016 - 07:06:30 AM »
👍  when you wired it...is there one hot wire that feeds the power on..and the rest of the switches are feed off of it??
Offline GreenFish
« Reply #17 on: April 12, 2016 - 08:11:30 AM »
The two wires are in your engine compartment already. The brown one is hot when cranking, the blue is hot in run. The way the switch is constructed, the blue wire gets power before the brown loses power. Tying those two wires together is how most MSD boxes are wired. :2cents:
ok, ill give that a go. The engine wire harness is completely removed at this point but I suppose I can re-purpose it and strip out all the voltage regulator, alt, etc stuff. It may make like easier
Offline 70chall440
« Reply #18 on: April 12, 2016 - 01:07:56 PM »
It isn't wired in yet (dash is still out), but yes, that is the plan; all power will come through the master. I will also have a battery disconnect switch that will be hidden.
Current Mopar
Past Mopars
Offline GreenFish
« Reply #19 on: April 12, 2016 - 01:12:04 PM »
Here you are
I like those switches. Who makes them?
Offline EB3-GranCoupe
  • BP23 U0B
« Reply #20 on: April 12, 2016 - 05:48:50 PM »
 :popcorn:
Offline 70chall440
« Reply #21 on: April 12, 2016 - 08:22:41 PM »
The switches themselves are generic toogle switches available anywhere. The part you can see are the offroad/marine covers. I get my switches from places like Del Electric, a lot of the stuff you buy locally is cheap.
Current Mopar
Past Mopars
Offline HP_Cuda
  • Mopar or No Car!
« Reply #22 on: April 12, 2016 - 09:10:42 PM »
I like the A/C switch...
Offline 70chall440
« Reply #23 on: April 13, 2016 - 12:34:26 AM »
In my case that will be for Accessories not Air Conditioning.
Current Mopar
Past Mopars
Offline GreenFish
« Reply #24 on: April 13, 2016 - 07:44:30 AM »
oh ok, cool. I just googled that I see now. I like the look. THanks
Offline 70chall440
« Reply #25 on: April 14, 2016 - 12:25:57 AM »
I got the plate from Speedway (I think, or maybe Ebay); either way I modified it to fit the opening.
Current Mopar
Past Mopars
