Author Topic: Frame rail replacement. Need help  (Read 2015 times)
Offline METAL BEE 68
« on: April 09, 2016 - 11:58:12 PM »
Ok guys, this is a big one. Ive got the k frame dropped on the challenger. And the drivers side frame rail is badly rusted. It needs to be replaced. I want to do this myself. I need to know how to go about doing it.
Offline Finoke
Re: Frame rail replacement. Need help
« Reply #1 on: April 10, 2016 - 12:47:58 PM »
Do you need to replace the whole rail or section in a piece? PIctures please.  :bigsmile:
« Reply #2 on: April 10, 2016 - 06:28:58 PM »
It needs the whole rail. I just posted pics on the Facebook page. Www.facebook.com/timschallenger
Offline Finoke
« Reply #3 on: April 10, 2016 - 08:29:07 PM »
Hey Tim, I emailed you a link to some pictures. Tom
Offline crocha617
« Reply #4 on: April 11, 2016 - 02:48:45 PM »
Wow that's one of the rustiest rails I've ever seen. Removing it should be easy at least.
« Reply #5 on: April 11, 2016 - 04:11:56 PM »
Yeah. The upper control arm bolts and bushing has fuesd together. It will be a job to replace, im sure. Still dont know how to approach it. Other than measuring alot.
Offline sassygreen
« Reply #6 on: April 11, 2016 - 07:58:30 PM »
support k member. Bolt it to the existing frame rail. Bolt the new frame rail to k member. This will give you the left to right dimension.  From there  square and level everything up tack weld in place. Install new inner fender. Tack radiator support back in place. Finally check hood, fender, front valance alignment. This should get you in the ball park. Hope this helps.
Offline dougs bs23
« Reply #7 on: April 11, 2016 - 09:51:42 PM »
before welding anything carefully measure everything and adjust to the frame alignment specs. They are in your fsm if you have one if not someone here will have a copy for your year. plumb, level and square everything, and before you final weld anything test fit all your panels
« Reply #8 on: April 12, 2016 - 12:14:02 AM »
Thanks guys. Fortunately someone close to home found out about the car and is coming out to help put it in.
Offline Beekeeper
« Reply #9 on: April 12, 2016 - 12:19:45 AM »
Just checking out all the work you did from your Facebook pics. Nice work. Impressive how much you got done. I have a 70 Challenger like that which will need similar work so I'm anxious to see how your frame rail turns out.
« Reply #10 on: April 12, 2016 - 04:00:08 PM »
Thanks.  I try to keep everyone up to date. I know it's fun to see a car get restored. And the guys here are great. Lots of knowledge.
