Author Topic: NAG1 Starter position  (Read 9632 times)
Offline soundcontrol
Re: NAG1 Starter position
« Reply #15 on: May 08, 2016 - 04:53:36 PM »
Well done, I'm sure you're not happy about the extra expense, but it looks the best solution.
Not that bad, 50 bucks for the bellhousing and 150 for the starter, comparing to cutting up my new TTI's, speding a lot of time cutting/welding the header pipes, then recoating them....
/ Ken
topic=108917.new#new
Offline 73440
« Reply #16 on: May 08, 2016 - 05:02:13 PM »
Was the top starter bolt on yours always a through bolt?
I stripped the top bolt hole on mine slightly and will have to drill for a through bolt.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #17 on: May 08, 2016 - 05:08:48 PM »
No, its not a though bolt,both have threads in the starter, its a bolt from my old starter, with threads on both sides, something else was attached to it, a heat shield I belive.
/ Ken
Offline 73440
« Reply #18 on: May 08, 2016 - 05:49:44 PM »
OK , I see that now.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline roadrunninMark
« Reply #19 on: May 12, 2016 - 11:31:12 AM »
Looking good, waiting to see how it all fits in the car!  Have an e.t.a.?  I am hoping you can get it all to fit without having to clearance the body.
« Reply #20 on: May 12, 2016 - 11:56:00 AM »
I'm hoping to get it drivable to next summer, I have to at least modify the T-bar crossmember, slim it down, the NAG1's connecting plate to the drive shaft ends up right on the crossmember. Can probably see how it all fits in this fall. (if work dosen't get in the way again...)
/ Ken
« Reply #21 on: May 12, 2016 - 11:57:44 AM »
Here is an excellent video on how to change the bellhousing on a NAG1 if anyone else wants to do this.
https://www.youtube.com/watch?v=FtI3IpMcuqg#t=1033
/ Ken
Offline 73restomod
« Reply #22 on: May 15, 2016 - 10:01:56 PM »
I just pulled a 04 Durango 5.7/545RFE, I will be stabbing it into my 79 w100 stepside. I noticed the 545RFE bell has provisions for starters on either side. The trucks used the drivers side and the durango uses the passenger side. The other hemi I pulled is from an 03 ram 2500. The 545 is a heavy trans it's almost 100 lbs more than the NAG, the ratios are also much wider than what you want for a car thou. The 545 has a one piece case as well.
Offline 73440
« Reply #23 on: May 15, 2016 - 10:19:53 PM »
If Torque= Force x Distance, when in the video he is holding the torque wrench close to the socket rather than at the handle, does that change the torque value?
Or is the Torque value the same and his Force has to be greater due to a shorter Distance ?
40 years ago , I would have known this answer.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline Katfish
  • 70 Challenger
« Reply #24 on: May 16, 2016 - 02:00:15 AM »
Less force to pull a long lever, more force to pull short, same torque.
Skinny kid has to sit at end of see-saw, fat kid closer in to balance.
Offline ntstlgl1970
  • T a c o c a t
« Reply #25 on: June 04, 2016 - 02:38:52 PM »
Supposedly the AWD LX Hemi cars have the starter on the drivers side as well, so there are other donors besides the Jeep around
Offline JpRngr
« Reply #26 on: October 05, 2016 - 05:06:16 PM »
So, have you done this yet? Curious how far you have to tear down the trans to do this swap. The video shows him with the trans mostly torn down.
« Reply #27 on: October 05, 2016 - 05:20:30 PM »
Have not done it yet, will do it soon, I will post an update when it happens. I don't think you need to take all the guts out though, just the parts thats bolted to the bellhousing.
/ Ken
Offline JpRngr
« Reply #28 on: October 07, 2016 - 05:13:56 PM »
Well, picked up a builder GC NAG1 today for $140. Ended up pulling the bell housing after I got it home. Pretty easy. Hopefully goes onto my Charger NAG1 as easy.
Corey
« Reply #29 on: October 07, 2016 - 05:21:04 PM »
Corey
Good deal for a NAG1! You'll probably get it done before me, I'm getting swamped with work, no time for the car right now. What car/engine combo are you building?
/ Ken
