Author Topic: Left turn signal on solid with running lights  (Read 1333 times)
Offline marcus
« on: April 12, 2016 - 10:47:36 AM »
This is happening on my 72 Challenger. All turn signals working fine then all of a sudden this morning I turn on the lights and I see my left turn signal light goes on solid with them.
Other than turning on with the running lights, the left turn signal still works.
Anyone ever experence this before? Any ideas where to start looking for the problem?
Offline GreenFish
Re: Left turn signal on solid with running lights
« Reply #1 on: April 12, 2016 - 11:38:09 AM »
My turn signals and flashers were doing some crazy stuff a few years back. I ended up replacing the small harness in the steering wheel and it fixed all gremlins.
« Reply #2 on: April 13, 2016 - 03:10:57 PM »
1 word .... Grounds , it need to make better contact with the body
Offline marcus
« Reply #3 on: April 14, 2016 - 10:54:04 AM »
Going to check all grounds this weekend...may also replace the blinker switch and harness. It feels really loose.
Offline marcus
« Reply #4 on: April 16, 2016 - 02:03:46 AM »
Problem went away before I had a chance to troubleshoot it!
Offline JayBee
« Reply #5 on: April 16, 2016 - 09:50:05 AM »
Sure sounds like an intermittent ground.
John
1970 Barracuda convertible
2014 Toyota Avalon
