Author Topic: Re-purposing blue and brown wires/ load capabilities  (Read 2577 times)
Offline GreenFish
« on: April 12, 2016 - 12:21:15 PM »
So after a discussion about starter buttons it seems to be a better option to use the brown and blue wires from the engine harness to power my megasquirt EFI.
My question now is if I use the blue and brown wires combined to power the ECU/injectors/fuel pump/coils etc. I am running all of that off of an existing/factory fuse right?
Then I'd be using additional fuses out to each component.
Would I be overloading the initial fuse in the factory fuse block which I think is probably a 20A? Should I just by bass that fuse or put a large 30A in there just for piece of mind?
What do you think would be the safest/best option? Right now I'm just using a large primary wire from the battery running a separate circuit on a toggle switch but I'd like to make it less "rigged"
Offline HP_Cuda
  • Mopar or No Car!
Re: Re-purposing blue and brown wires/ load capabilities
« Reply #1 on: April 12, 2016 - 12:24:36 PM »
The blue and brown wires which go to your ballast resistor?
Don't you need a straight 12V all the time for megasquirt?
Offline GreenFish
« Reply #2 on: April 12, 2016 - 01:12:45 PM »
The brown one is hot when cranking, the blue is hot in run
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: April 12, 2016 - 01:20:09 PM »
So then you only want to tap into the blue wire, which was my point.
Offline YellowThumper
  • I left the snow for this?
« Reply #4 on: April 12, 2016 - 01:36:13 PM »
As previously mentioned both ate needed.
While one is hot cranking the other is dead.
Stop cranking it goes dead and the other becomes hot.
GreenFish
Use those to power a relay. Your relay feeds the ms.
As a side note I tapped into my fuse block inside the car for the relay that is powering my ms. Hot cranking and also in run. But is not powered in the accessory mode. I will look and see if I can get a pic or ID location of it.
Offline GreenFish
« Reply #5 on: April 12, 2016 - 01:39:53 PM »
You need 12v in both for the MS
Offline GreenFish
« Reply #6 on: April 12, 2016 - 01:41:45 PM »
GreenFish
Yes, that is sort of what I was getting at. My 12v now is right from the battery to the relay. Ill just replace my hot wire from the battery with a wire that splices the blue and brown and then goes into my relay ..
Right?
So do i need to worry about the factory fuse at all?
« Reply #7 on: April 12, 2016 - 02:00:23 PM »
Yep on the first.
No on the second as triggering the relay is a minimal power draw.
Really itching to get back at mine.
Good luck
Offline GreenFish
« Reply #8 on: April 12, 2016 - 02:06:54 PM »
Yep on the first.
Good luck
perfect.. thanks
« Reply #9 on: April 12, 2016 - 03:42:56 PM »
Yes, trigger a relay with the brown/blue wire combination, but don't ever switch out a 20a fuse for a 30a!
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: April 12, 2016 - 08:58:38 PM »
Ahh you just wanted to trigger on the blue/brown - make sense.
If you are going from the relay you are already halfway there.
« Reply #11 on: April 13, 2016 - 03:25:21 PM »
You can shunt power from the start relay on the inner fender to a second fuse block & run the extra circuits from  second fuse block & use a heavy relay 40amp to power off the secondary fuse block , the coil packs should be ok as well as the ECU from the existing Blue/brown wires , the injectors are powered from the ECU , but  the fuel pump is better run from a relay
Offline GreenFish
« Reply #12 on: April 14, 2016 - 07:26:11 AM »
Good idea too, ill consider that also.
« Reply #13 on: April 14, 2016 - 04:28:50 PM »
Effectively that is what I did for the fuse/relay block I have up front.
