Author Topic: Shackle  (Read 3687 times)
Offline Cuda_451
Shackle
« on: April 12, 2016 - 08:35:43 PM »
Does anyone make offset shackles for the 70 Barracuda? What's the cons of them?
1970 Plymouth Barracuda
1995 Dodge RAM 1500 SLT
2006 Ford Mustang V6 Supercharged
Offline 70chall440
Re: Shackle
« Reply #1 on: April 13, 2016 - 12:54:16 AM »
Current Mopar
Past Mopars
Offline Cuda_451
Re: Shackle
« Reply #2 on: April 13, 2016 - 01:12:38 AM »
Would just shackles help align the springs? I have a narrower rearend than stock so it's got a very awkward tilt to it
Re: Shackle
« Reply #3 on: April 13, 2016 - 06:34:00 AM »
When you use offset shackles you also need to use an offset hanger and usually reposition the mounts on the rear end. Most do this to add clearance for bigger tires, if you use a older B-Body rear end you won't need to move the brackets on the housing.
Offline Cuda_451
Re: Shackle
« Reply #4 on: April 13, 2016 - 08:55:30 AM »
How would I reposition the mounts? And it is an older 8 3/4
Re: Shackle
« Reply #5 on: April 13, 2016 - 08:56:25 AM »
Cut them off and weld on new ones. They are cheap to buy.
Offline Cuda_451
Re: Shackle
« Reply #6 on: April 13, 2016 - 10:39:46 AM »
 :working:are you talking about the leaf mounts on the axle? Could I not use the factory ones?
Re: Shackle
« Reply #7 on: April 13, 2016 - 11:00:08 AM »
yep, the old ones would be in the way of where the newly positioned ones need to go.
Offline Cuda_451
Re: Shackle
« Reply #8 on: April 13, 2016 - 01:17:07 PM »
Okay, thanks!
Offline Locke
Re: Shackle
« Reply #9 on: April 13, 2016 - 06:05:36 PM »
I just replaced the leaf springs in one of my cars and used an offset hanger kit from DoctorDiff to allow a bit more clearance.  You'll have to get new spring perches to weld to the axle housing, Dr. Diff sells them too.
Locke
Two (2) 71 Barracuda Convertibles
Offline Cuda_451
Re: Shackle
« Reply #10 on: April 13, 2016 - 11:08:27 PM »
Just wish there was a way without changing the perches.
Offline 70chall440
Re: Shackle
« Reply #11 on: April 14, 2016 - 12:19:22 AM »
Unfortunately there isn't any free lunch when it comes to something like this. Its all "cause and effect"...
Current Mopar
Past Mopars
Offline 1 Wild R/T
Re: Shackle
« Reply #12 on: April 14, 2016 - 12:38:22 AM »
Replace the housing & axles with a housing & axles from a 68-70 B body, the axles are 1.25" shorter then E body axles, housing is 2.5" narrower than E body housing & the spring perches are 3.0" narrower than the E body perches so it will drop on the relocated leafs....
Re: Shackle
« Reply #13 on: April 14, 2016 - 08:03:42 AM »
Locke
I thought if you use the narrower 68-70 B-Body rear housing that only the 1" offset spring hanger kit was required....  http://www.doctordiff.com/e-body-offset-spring-hanger-shackle-kit.html
Offline shawge
  • Zoiks!!
Re: Shackle
« Reply #14 on: April 17, 2016 - 02:52:33 PM »
 :iagree:  that is what I did.
- Jerry
