Author Topic: Transmission pan Gasket  (Read 1201 times)
Offline noreastfish
« on: April 12, 2016 - 08:51:19 PM »
I was wondering what you would suggest I us on a cork transmission pan gasket. Do you put any sealer on the gasket or just put it in dry and torque the bolts. I can't seem to get the transmission to stop leaking.
Offline GoodysGotaCuda
Re: Transmission pan Gasket
« Reply #1 on: April 12, 2016 - 08:56:31 PM »
If you get a steel reinforced plastic one from the dealer, it holds up very well. I want to say it was factory on 80's transmissions, someone here likely has a part number.
As far as using a cork gasket, i always use a very thin coat of rtv on both sides and tighten it just enough to start to squeeze the gasket.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 73_Cuda_4_Me
« Reply #2 on: April 12, 2016 - 10:00:41 PM »
I use the Chrysler gasket... pricy, but no leaks since installed...  Mopar Part number 2464324AC
Also, if using factory steel pan, make sure the flange is flat where the bolts go through... the pan usually flares toward tranny at bolt holes from over-torqueing over the years to stop leaks (just makes it worse)... use a socket under the lip and hammer them back flat with drift pin/bar stock/old bolt.
« Last Edit: April 12, 2016 - 10:04:58 PM by 73_Cuda_4_Me »
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
« Reply #3 on: April 13, 2016 - 09:57:36 AM »
or skip the gasket & just use a bead of silicone
Offline YellowThumper
  • I left the snow for this?
« Reply #4 on: April 13, 2016 - 01:08:37 PM »
But don't over tighten it and squeeze everything out.
Offline Mopar Mitch
« Reply #5 on: April 13, 2016 - 02:45:48 PM »
The dominant reason for trans pan leakage is always an out-of-flat surface... bolt holes out-of-shape, etc.   DON'T overtighten!!!   Cork-rubber eventually saturates (given a few years down the road); rubber can easily split if overtightened.  Avoid chemical sealers unless you simply want to attach the gasket.
« Reply #6 on: April 13, 2016 - 02:49:07 PM »
the Caravans I run for my business never use a gasket just a silicone seal & they stay bone dry
