News:
It has been a few years since I installed my FAST system. But if I remember correctly there is a safe mode on the ECU that wont allow the injectors to fire unless everything is programed correctly. Is you ECU programmable?All my notes are at home, so once I get there I will check to see exactly what was needed.Also, you say it runs on starting fluid, have you tried to pour some fuel in to see if it will run longer once started?I am sorry you are having these problems....my no start issues with the FAST system turned out to be a software issue when I updated the system. turned out to be an easy fix once we figured it out....and it only took three week.
You should put an ammeter on the line and see what it draws so you can size the fuse accordingly. I would assume that 5A is way more than enough for injectors. B
