Author Topic: Slapstick shifter, linkage and brackets-SOLD  (Read 812 times)
Offline Challenger in NC
« on: April 17, 2016 - 09:21:13 AM »
The setup includes some of the washers, clips and bushings but there will be some miscellaneous clips and screws needed. There is also one bracket that you will need to get called a gear shift control torque bracket. Its readily available from places like Mancini Racing . I would also get a new shifter bezel since the original plastic is pitted and maybe a torque shaft rubber boot.
For the shifter and shifter linkage, I'm asking $175.
For shifter, linkage and shifter/console brackets, $200 (brackets would need to be cut off from old trans tunnel, or just buy some new repro ones)
Chris
« Last Edit: April 25, 2016 - 09:00:57 PM by Challenger in NC »
Re: Slapstick shifter, linkage and brackets-SOLD
« Reply #1 on: April 25, 2016 - 09:00:02 PM »
SOLD
