Author Topic: Difference between 0w40 and 15w40  (Read 14630 times)
Offline leanburn
« on: April 17, 2016 - 02:13:28 PM »
 I was having a bs section with a buddy and we started talking oil weights. From my understanding the first number represents the oils viscosity at colder temps and the seconds is at running temp. Is there any reason an engine can't run 0 weight oil year long? I know it's not necessary and more expensive but other than that ?
Offline YellowThumper
  • I left the snow for this?
Re: Difference between 0w40 and 15w40
« Reply #1 on: April 17, 2016 - 04:40:49 PM »
When engine is cold you want the thinner oil so it flows throughout the engine more efficiently. As things warm up you need the heavier viscosity to provide enough of a barrier under normal load usage. Going with a single heavier viscosity would always be better than going the thinner. The thin weight is only for initial startup when everything internal is a bit tighter prior to heat expansion.
Offline leanburn
« Reply #2 on: April 17, 2016 - 04:52:05 PM »
So does that mean that you could run 0w40 in summer months with no ill effects ?
Offline rt green
  • third string oil changer
« Reply #3 on: April 17, 2016 - 05:44:04 PM »
 the difference is if you pour 15w40 in a glass it would pour like 15 weight. 0 would pour like 0 weight. both will lubricate like 40 weight.
Offline leanburn
« Reply #4 on: April 17, 2016 - 07:03:57 PM »
Ok, so 0 weight oil year around no problem but then that brings me to another question.  If you require a 40 weight oil why would anyone bother with 20w40 vs 0w40?
Offline blown motor
« Reply #5 on: April 17, 2016 - 09:48:25 PM »
But don't the two weights become a homogenous mixture? It's not like they separate and pump separately.  :clueless:
Offline msbaugh
« Reply #6 on: April 17, 2016 - 10:33:31 PM »
Lol.... Dude, it's not just two different oils mixed together.   Physical properties change as temp changes.  All oil thins with heat and thickens when it's cold. With multi weight it just changes differently and is tailored better due to the additives for start-up and different ambient temperatures.  It's still thicker when it's cold than it is warm, it's just that a 0w40 flows easier at 40 degrees F than a 15w40 at the same temp.  There won't be any issue running 0w40 in summer other than that you'll be wasting money.  I run 15w40 in my diesel most of the year and only change to the 5w40 if it's due during winter time
« Last Edit: April 18, 2016 - 07:03:41 AM by msbaugh »
« Reply #7 on: April 17, 2016 - 11:03:43 PM »
I've been running 5w40 in my diesel for 7 years now. Summer and winter.
Offline RCCDrew
« Reply #8 on: April 17, 2016 - 11:17:08 PM »
I'm no chemist, but is has to do with the different types and amounts of polymers in the oil. Polymers like to bind to things and keep them in suspension, and are the determining factor between single weight and multi weight oils, IIRC.
Offline blown motor
« Reply #9 on: April 18, 2016 - 08:52:23 AM »
And that's why I'm not a scientist.  :grinno:
Offline quagmire
  • Traction Impaired......
« Reply #10 on: April 18, 2016 - 07:55:48 PM »
Sheer stability drops dramatically as the spread between the two numbers increases.  This is the major reason why you cannot run 0w40's in most engines year round, or at least in areas that'll see extremely high ambient temps.
Basically, the oil viscosity index improvers responsible for making multiviscosity oils possible will "shear" and breakdown over time (how quick depends on drive cycle, ambient temps, engine design, load, etc.) and cause the oil to no longer be a 40 weight when hot.  So what started out as a 0w40 may quickly become a 0w30 or even a lower.  As that occurs, engine protection drops and reach a point where sludging, accelerated wear, and damage begin to take place.
This is a major reason why 10w40 was abandoned as a common weight many years ago.  Being conventional oils, they caused a lot of problems because the additives weren't stable long term.
Modern synthetics and extended life additives allow some of these extreme weight spread oils to exist, but they still are susceptible to shearing, just less so.
Offline msbaugh
« Reply #11 on: April 18, 2016 - 10:48:52 PM »
Then how are 15w40 and their 5w40 synthetic counterparts from delo, amsoil, and rotella the industry norm and best oils for diesel trucks and heavy duty applications? Ppl run oil analyses on these up to 10k miles without significant degradation or wear.
Offline quagmire
« Reply #12 on: April 19, 2016 - 08:32:42 PM »
0w40 has a large viscosity spread, 15w40 does not.  That's why 15w40 has always been a proven oil in HD applications.  You're subtracting the difference between the two numbers.  The larger the difference, the more viscosity improvers are used for a given oil type that can/will shear.
Also, I specifically stated that synthetics are less prone to this.  I'm not aware of any conventional 5w40 oils, ALL of the normal players in the HD diesel world are a synthetic blend at a minimum or more often a full synthetic.
Many HD diesel engines in trucks can go far more than 10K miles nowadays; 30-50K miles is possible in most modern engine designs with the correct oil filter and high MPG drive cycle.
« Last Edit: April 19, 2016 - 08:39:15 PM by quagmire »
Offline anlauto
« Reply #13 on: April 19, 2016 - 08:46:46 PM »
Man....I wanna say "15" so bad...... :roflsmiley:
Offline msbaugh
« Reply #14 on: April 19, 2016 - 09:00:40 PM »
Makes sense. What do you mean say 15?
