Author Topic: 6pk solenoid  (Read 1887 times)
Offline mytmopar
  • 69 gtx 440 vert-71 chally 340 blown-70 R/T coronet
6pk solenoid
« on: August 31, 2002 - 10:40:11 AM »
what is the purpose of the 6pk solenoid and do you have to have it to opperate a six pack setup. i got in touch with koller dodge and the parts guy said that they do not make this part anylonger and that i would have to find one in a junkyard. if i do need it does anyone have an extra for sale?  thanks mike in tn
thanks for the ad
get in, sit down, buckle up, and hold on! see you later, BYE!!
Re:6pk solenoid
« Reply #1 on: August 31, 2002 - 12:47:26 PM »
 It just stops dieseling by closing the the throttle plates fully , it is not nessisary to have it , the 6 packs will work without it.
Try 6pack Performance in New Mexico[505] 345-8539, he used to sell them & probably still does
Offline BadHemi
Re:6pk solenoid
« Reply #2 on: August 31, 2002 - 01:49:31 PM »
You can buy a replacement from many sources, (try your local auto parts store! You might be surprised) the only problem is that they have a superceded part# and a different shaped plunger head. So, if you are going for OEM show quality they are not 100% correct in appearance (but VERY close!) and they work just as OEM did.
