Author Topic: trunk inner rear quarter undercoat  (Read 1465 times)
Offline culp71
« on: April 21, 2016 - 09:50:50 AM »
wondering on a 71 cuda if the insides of the rear quarters where sprayed with some type of undercoating or textured rubberized paint? I seem to recall that I've seen pictures of e-bodies with this inside the trunk area on the rear quarter panels up to and even over the marker lights.
is this correct, did the factory do this?
wondering if it should be done on a full stock restoration to be similar to original.
did they all have this?
thanks
« Last Edit: April 21, 2016 - 10:05:46 AM by culp71 »
Offline anlauto
Re: trunk inner rear quarter undercoat
« Reply #1 on: April 21, 2016 - 10:13:26 AM »
YES..it's sound deadener and should be applied BEFORE paint. :2cents:
Offline culp71
« Reply #2 on: April 21, 2016 - 10:43:33 AM »
oh boy, so it should be body color then not black.
should it go up onto wheel well or just inside skin of quarter only?
was applied before marker installation then.
« Last Edit: April 21, 2016 - 10:45:31 AM by culp71 »
Offline 340challconvert
  • A66- Challenger Registry
    • A66CHALLENGER.COM
« Reply #3 on: April 21, 2016 - 11:29:32 AM »
Restoring my car as a driver: 70 Challenger A66
Have a mostly original car in storage since 1984.
Picture of the trunk inside quarter showing the sound deadener, as per the factory
You can see how it was sprayed!
« Last Edit: April 21, 2016 - 11:43:30 AM by 340challconvert »
1970 Challenger A66 Registry
Offline culp71
« Reply #4 on: April 21, 2016 - 11:45:27 AM »
that's excellent! thanks guys.
pics worth thousand words.
probably similar to how a cuda would be applied, me thinks?
Offline Challenger in NC
« Reply #5 on: April 21, 2016 - 08:56:29 PM »
Any recommended brand that gives the best reproduced texture or are they all about the same?
Offline culp71
« Reply #6 on: April 28, 2016 - 01:28:03 PM »
I've been experimenting with various undercoats and sound deadeners, even bed liner rolling kits
but have not found anything that is close enough, anyone have suggestions how to recreate this?
Offline AARTA340
« Reply #7 on: April 28, 2016 - 02:36:35 PM »
I have not personally used the product, but the "Big Boys" highly recommend Resto Ricks products.
http://www.restorick.com/proddetail.asp?prod=Undercoat   :2thumbs:
