Author Topic: Key Removable 70 Cuda  (Read 2499 times)
Offline DirksCuda
« on: April 21, 2016 - 03:23:18 PM »
Can someone tell me how to get the key out of the ignition on a 70 Cuda  340/4 spd car. The colum is out of the car but the key won't come out. I was thinking maybe the transmission may have to be in reverse. Thanks for any help Dirk
Offline anlauto
Re: Key Removable 70 Cuda
« Reply #1 on: April 21, 2016 - 03:39:34 PM »
On the bottom of the column there's two little notches, turn the collar until they line up :2cents:
Offline 1 Wild R/T
« Reply #2 on: April 21, 2016 - 07:45:57 PM »
And for those who don't speak hieroglyphics...
When looking at the column from the steering wheel end the are three collars, the first has the turn signal lever sticking out, the second has the ignition switch & the third one is the one you need to grab and twist counter clockwise as viewed from the drivers seat....
The notches Alan is referring to are on the underside of the last two collars.....
Offline anlauto
« Reply #3 on: April 21, 2016 - 09:01:49 PM »
Yea....I was going to say that.....but I had to get back to work you know....there's only so many hours in the day... :smilielol: :smilielol: :smilielol: :smilielol:
Offline 1 Wild R/T
« Reply #4 on: April 21, 2016 - 10:18:08 PM »
I totally understand...What with six hours on the day's project, Dr Phil, Rerun's of Happy Days & I dream of Jeanie.... :rofl:
Offline DirksCuda
« Reply #5 on: April 22, 2016 - 07:25:41 AM »
Is that just to get the key out of the ignition. Im not trying to take the ignition out. Thanks Dirk
Offline anlauto
« Reply #6 on: April 22, 2016 - 08:02:15 AM »
YES...that's just to get the key out. :2cents:
Offline CUDA JAS
  • vroooooom!
« Reply #7 on: April 24, 2016 - 08:26:03 AM »
And make sure the key is in the off/lock position. Remember all the way back towards you is the acc position. You will never get the key out if its in that position.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline anlauto
« Reply #8 on: April 24, 2016 - 09:40:28 AM »
Jason
That's the deal with a 1970 column, you can't get it into the position unless the two notches are lined up.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #9 on: April 24, 2016 - 02:00:22 PM »
Good grief Charlie Brown!!!
Easy method: reach under the steering column, grab the can which is just behind your turn indicator lever, and turn it to the left. This is true if the lockout is not hooked up, since it's out of the car then it's not hooked up!!!
