Hello to the Group!
Please forgive for this long winded message but I feel I need to show history. Recently I purchased a 73 Cuda, with a stock 340. No modifications that I can detect on the engine - it does have headers. Just got it on the road almost 3 weeks ago. This summer is the 'shake down cruises' as far as detecting issues and putting a priority on them. First thing I noticed is the initial crank of the engine. There is one turn, a delay and then it starts. Went to Pep boys and determined the battery needed replacement - they test the battery for free - 45 min test. GREAT! replaced the battery - problem solved. Well installed the new battery and the cranking is noticeably better and I'm happy. Yesterday drove the car for about 20 minutes got a ice cream with the misses so the car sat for 20-25 minutes before starting it. Went to start it and the cranking sounded very different plus it would not turn over, finally there seem to be a moment of silents and finally it just started but not the usually way it starts cold- like a good crank and starts. It was a low cranking sound?? no clicking from the starter however.
So I'm thinking heat seems to rule the day on the starter system. Got home (another 20mins) after our little trip and immediately turned the car off and then started the car. Started with no issues. OK well maybe it's not the heat so then I waited another 20 minutes to duplicate what happen before. Sure enough, the car had a very bad time starting indeed, almost the same characteristics as I descripted above.
I'm not a mechanic so I'm big time lacking in this area, but my thinking is to start replacing things up to the starter before replacing the starter itself. I'm just looking for feedback as to how to attack this issue. Thanks for reading!!!!
