Author Topic: torsion bar sizes  (Read 4989 times)
Offline EbodyMod
  • Will it ever be finished????
torsion bar sizes
« on: April 25, 2016 - 08:48:03 PM »
I am looking at upgrading my torsion bars and i know of a set of 774 bar and 775 bar for sale i currently have even smaller and was looking at the 1.03 hotchkiss ones.  Any opinions ??? :clueless:
:wavingflag:  Quit being offended by everything, I am sure you are doing something that upsets me, but I am not complaining about you!!! It is a free county get over yourself!
Offline anlauto
Re: torsion bar sizes
« Reply #1 on: April 25, 2016 - 08:53:36 PM »
774/775 measure 0.86"
Offline EbodyMod
« Reply #2 on: April 25, 2016 - 08:59:55 PM »
i know,  i hoping someone could comment on the handling difference.i am sure the smaller ones will be kinder to my wallet but don't want to "cheap out"
Offline anlauto
« Reply #3 on: April 25, 2016 - 09:59:26 PM »
I've been buying torsion bars at my local dealership. They seam to have the best prices. Check with David or Jon at Roseville first fore a price. Mopar has 0.96" and even 1.22"
« Reply #4 on: April 25, 2016 - 11:53:16 PM »
.96 would be the minimum size to use , over 1" is normal
« Reply #5 on: April 26, 2016 - 10:45:01 AM »
.88 vs 1.0, this is 100# wheel rate vs 175# wheel rate. Wheel rate is the applied spring rate at the center of the tire. In the case of a mopar, these two are actually the same. The 175# rate is in the territory of where a modern car would be. This will produce less body roll, less chance of bottoming out, and a firmer overall ride.
The .88 bars is what was normally offered in  six and 318 cars back in the day. They are a comfortable ride. If you decide to got with these, you will run the chance of bottoming out the suspension on occasion and you would need to step up to a 1.125" or 1.25" front sway bar to reduce the body roll they will allow.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #6 on: April 26, 2016 - 11:44:40 AM »
I have 1.10 Hotchkis on my Cuda and it made a big difference over the .88.  Much better feel for the road and not too stiff.
Offline Mopar Mitch
« Reply #7 on: April 26, 2016 - 04:07:21 PM »
I've tried many different TBs... car was progressively built for SCCa pylon AX...  I settled with the largest size of 1.24" (hex opening is 1.25")... these TBs rated at 425 # per inch (from a past Mopar compony called California Moparts/Suspension  i the 80s... they later went out-of-business... too bad, ahead of their times.
I've offered mu opinions from past experience - don't be afraid of larger TBs.   Even at my current 1.24", they're not as stiff as you may think.  sure, the ride is stiffer, but its completely still driveable for the street/hwy... as long as you don't routinely drive over pot holes and rough train track crossings (just slow down then or avoid that drive as much as possible... no fun!).
As HP2 has similarly said, with soft TBs your car has more of a tendency to bottom out, and the lift/lean will prevail.
Consider nothing less that ~1.12 for a SB car... or even 1.18 for a BB car... you won't regret it and only wonder WHY you didn't install these larger TBs earlier.  Call Firm Feel as they readily have the 1.12 and 1.18 in-stock... and they'll gladly make you larger (up to 1.24).
ALSO, consider spending good $$ on good shocks... you pay for what you get.   I recommend double adjustables (Viking, QA1, Starnge, others)... the Vikings are probably the best buy as they originated from the QA1 designs (same past people), and Viking ONLY makes 2x shocks to keep their costs down.
AND... consider stiffening your rear leafs a little... too stiff an you'll really feel it... current "handling" leafs (from various vendors) are all pretty good.
I suggest to use the sway bar sizes as a fine-tuner in the handling... your choices prevail.
« Reply #8 on: April 26, 2016 - 09:31:32 PM »
1" minimum t-bar. With a minimum 1 1/8" sway bar.  :2cents:
Offline EbodyMod
« Reply #9 on: April 26, 2016 - 09:46:06 PM »
I have already installed RMS street lynx in the back with Viking Double adjustables. full qa1 up front k-member, upper and lower control arms, strut rods. firm feel quick ratio pitman, idler arms and a  stage 3 box. i want it stiff but not ridiculous. i am shooting for a modern perfomance car type handling
« Reply #10 on: April 27, 2016 - 08:20:54 AM »
 :iagree: from a performance perspective the Mopar bars are junk. They are not consistent. Buy them from Firm feel, no headaches.
« Reply #11 on: April 27, 2016 - 10:01:36 AM »
In this case, call Bill and see what he would recommend to compliment the rear set up you already have.  If you want modern type handling, the .88 bars are out, even if they are free.
Offline soundcontrol
« Reply #12 on: April 27, 2016 - 10:47:36 AM »
Firmfeel recommended 1" for me, I had a 340 at the time, but now its gonna be a 6.1 but I think the weight is about the same.
/ Ken
topic=108917.new#new
Offline Mopar Mitch
« Reply #13 on: April 27, 2016 - 11:18:58 AM »
1" TBs still way too soft... barely noticable... install the compromise at 1.12" (FF) and you'll still wonder why you're not installing larger TBs... such as 1.18" (FF).   I suggest these sizes with consideration that the car isn't going to be prominently used for higher-levels of AX/HSA/HPDE, etc., in which case you'd desire 1.18 and higher.... you'll find out, sooner or later.
Offline EbodyMod
« Reply #14 on: April 27, 2016 - 03:27:37 PM »
Thanks for the input guys, I think I am going to go with the 1.12. I know it wont be an autocross car so i will put it on the high end of the range without maxing out. :thumbsup:
