Red Cap battery
Author Topic: Red Cap battery  (Read 2072 times)
Offline ct440rod
Red Cap battery
« on: April 26, 2016 - 09:43:52 AM »
Not sure if I want to spend the money for a red cap battery for 70 challenger right now. What brand battery looks good under the hood ? ?
thanks
Offline 4406v
Re: Red Cap battery
« Reply #1 on: April 26, 2016 - 01:29:56 PM »
Buy a good black case battery and peel the decals off it. It may not look "correct" but at least it won't look "wrong".
"Live for today, Tomorrow never comes"
Offline GreenFish
Re: Red Cap battery
« Reply #2 on: April 28, 2016 - 01:03:08 PM »
if you use an Optima, get a battery tender. They don't do well sitting for long periods of time. I used to go through one every year until they changed the warranty then I stopped buying them.
Offline AARuFAST
  • AARuFAST
Re: Red Cap battery
« Reply #3 on: April 28, 2016 - 07:30:22 PM »
I don't think you can us a battery tender on the gel cell batteries.
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline roadman5312
Re: Red Cap battery
« Reply #4 on: April 28, 2016 - 08:16:44 PM »
                 Your right, read the instuctions carefully if you buy one.   :iagree:
Offline 1970TA
Re: Red Cap battery
« Reply #5 on: May 02, 2016 - 11:42:20 PM »
Optima Batteries are AGM (absorbant glass mat) batteries, not gel cell.
The "Battery Tender Plus" is designed for AGM batteries.
From the Battery Tender website:
"RECHARGING AGM BATTERIES: The Battery Tender® has an absorption charge mode, but the the Battery Tender® Plus has a different absorption mode maximum charge voltage and a timer to hold the absorption voltage longer. These specific changes were made to accommodate the charging requirements of Absorbed Glass Mat (AGM) style lead acid batteries."
Re: Red Cap battery
« Reply #6 on: May 03, 2016 - 12:50:53 AM »
This is what is called an algorithm.
http://nyc-arecs.org/charging.pdf
Offline GreenFish
Re: Red Cap battery
« Reply #7 on: May 10, 2016 - 01:06:09 PM »
I have an AutoZone brand AGM, I use a tender on it all the time. Get a tender
